switched power that's constant while cranking 06 silverado
Old Oct 24, 2010 | 08:54 PM
NicD's Avatar
9 Second Club
Default switched power that's constant while cranking 06 silverado
Alright I am trying to locate a switched power source key on/off that doesn't switch off during cranking to wire up my electronic boost gauge with. The typical accessory power wire that I have found turns off during cranking which throws off the digital boost gauge's calibration sequence. Any ideas?
It's an 06 Silverado without the bose setup.
Thanks!
Old Oct 24, 2010 | 09:05 PM
Bigredmariner's Avatar
There should be a pin available in the junction box down in the floorboard. The one right by your left foot when sitting in the seat, check the upper left area of it with a test light, I'm not sure of the exact pin number. And I don't have a pic of it but that's where I tapped power for my gauges. I used some miniature female spade connectors and slipped them over the pins then ran that to a fuse block.
Old Oct 24, 2010 | 09:23 PM
NicD's Avatar
9 Second Club
Alright, after more probing I found a yellow wire coming from the steering column that runs into a plug right below the column that stays hot during cranking so I tapped into that one.
Old Oct 24, 2010 | 10:02 PM
skolman91's Avatar
yellow for the most part usually means airbag, dont think i would mess with that one but thats up to you..
Old Oct 24, 2010 | 10:58 PM
Yeah I think I would stay away from the yellow wires too. I don't have a schematic so I was leering of just tapping into any old wire, check that junction block I was telling you about, there are several keyed power pins there to use. I used one for my gauges and another for my cutout.
ARC
57
Feb 21, 2022 10:54 AM
atxlt
Jul 20, 2015 11:06 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
grantpo
Jul 15, 2015 12:21 PM
GreyChevy
Jul 7, 2015 08:57 PM
