Sub Enclosure Question?
Old Sep 4, 2008 | 11:26 AM
nova1man's Avatar
Default Sub Enclosure Question?
I have a 2007 Classic Crewcab and bought a subthump box that houses 2 10's. Its limited to what size 10 you can use and wanted to know if anyone can recommend a good, not a decent sub, but good. Its limited to depth of 5 5/8" and magent diameter of less than 6" . I have a Memphis PowerReference series amp 500.1 which is a mono amp . Any help is appreciated.
Old Sep 4, 2008 | 07:31 PM
53bowtie's Avatar
how bout some memphis pr's to go with that amp?
Old Sep 4, 2008 | 09:17 PM
nova1man's Avatar
Thats what I wanted to use but the magnet diameter is too big
Old Sep 6, 2008 | 09:44 PM
53bowtie's Avatar
well if those are too big you may be out of luck. PR's are some of the shallowest woofers around since they are memphis's entry level sub. You may look into getting a different box that will allow for a larger magnet diameter. I know they make them for our trucks.
Old Sep 7, 2008 | 12:22 AM
nova1man's Avatar
Not for under the seat and i do not want to relocate the jack. I have found several that will work. I figured I would ask here forst but wasnt much help, lol
Old Sep 7, 2008 | 09:24 AM
53bowtie's Avatar
well alot of us make our own boxes to fit the sub, not buy a prefab and have to find a sub to fit the box. Good luck with your search, sorry we were not much help.
Old Sep 10, 2008 | 07:12 PM
tallChevy's Avatar
do a search of shallow mount subwoofers I know both kenwood and pioneer make them I would say go with the kenwood excelon and a 400-500rms watt amp
Old Sep 10, 2008 | 07:48 PM
006rcsb's Avatar
try the treo ssi 10 inch sub, its relatively shallow at 5.1875 inches mounting depth, or the re audio re10, or the sr10 might work but it would be tight both brands are very good subs for sq
Old Sep 11, 2008 | 08:40 AM
blainesdad's Avatar
Registered User
Fosgate makes one that will fit in there, they are shallow mount, I just can't recall the product#, just check their site, I here they work well in your set up. This is a downfire box under back seat right?
Old Oct 11, 2008 | 07:40 AM
gmc6's Avatar
thats correct
