Radio doesn't work when truck is moving
Old Jun 22, 2014 | 08:20 PM
Richardman1992's Avatar
Default Radio doesn't work when truck is moving
Hey guys I need help FAST! I just installed a new radio (Sony mex5000bt) in my 01 silverado, and after a bitch of a morning/afternoon and my uncle missing his flight due to helping me install it, I have the radio working. The problem is that as soon as I start moving, the radio stops playing and the lights go out. I have the red wire from my radio harness hooked up to the green and white striped wire. If that is not correct, where does it go? I'm leaving for Utah and need this radio working ASAP! Thank you
Old Jun 22, 2014 | 08:53 PM
Chevy_King1500's Avatar
make sure there isn't a wire shorting out on the back of the head unit
Old Jun 22, 2014 | 09:01 PM
Everything is soldered and heat shrunk. And wouldn't it do that even if it wasn't moving?
Old Jun 22, 2014 | 09:08 PM
you would think. so when you put it in drive it just shuts off?
Old Jun 22, 2014 | 09:12 PM
Only when I am moving. And intermittently it will attempt to start up again and play for a second or two and then shut off again
Old Jun 23, 2014 | 10:03 AM
I don't know what my problem was but we ended up wiring the red wire on the radio harness to the wire for illumination so all I have to do is turn on my lights for the radio to work
Old Sep 29, 2014 | 02:52 PM
SlickBeast's Avatar
Pretty much rewire the power?
Old Sep 29, 2014 | 03:22 PM
Txblue's Avatar
It's been a while since I've installed a radio but either the red or yellow wire goes to a constant 12 volt the other goes to a key on 12volt. One is usually a thicker wire (on the radio harness). The thicker one goes to constant 12 volt.
Old Oct 5, 2014 | 08:32 PM
FatherSonSS's Avatar
You might have tapped the wrong wire, maybe a speed sensor or something ?
Weird nonetheless
-Matt
Old Nov 1, 2014 | 05:20 PM
I don't know... But it's been working great the way it is since June
wrb002
Aug 31, 2015 12:00 PM
chacho44
Jul 16, 2015 09:03 AM
black6spdz
Jul 16, 2015 01:32 AM
