radar detector hard wire
Old Nov 2, 2005 | 05:58 PM
stone150's Avatar
Default radar detector hard wire
i want to hard wire my radar detector to my truck, my friend had it done in his mustang and it was so much better. should i wire it to the map/compas wires or should i run it up the headliner and down the a pillar to some other wires. want it to come on with the truck, what do you recomend and what wires/ fuses should i look for?
Old Nov 2, 2005 | 06:06 PM
thunder550's Avatar
High on diesel fumes
I have a Passport 8500 with the hard-wired remote. I ran the wire down the passenger a-pillar, inside the dash to the remote next to the airbag switch, then across to the driver's side fuse box. I am at work right now but I will take a peek later and check which wire I tapped into. I really like having it hard-wired, I hate cigarette lighter plugs and avoid them whenever possible. The wire that I grabbed turns the detector on when the key is on run or on accessory.
Old Nov 2, 2005 | 08:44 PM
dewmanshu's Avatar
Moderately Differentiated
I have the Valentine One and I hard wired the same as Thunder did. Make sure you fuse it and have it on a "keyed" hot connection as so it's only on when the accessories are on or the truck is running...which means going down the A-pillar.
Old Nov 3, 2005 | 12:41 AM
Coban's Avatar
i put a female plug in my over head console right by the windshield and a male plug on the power wire for my radar. I pulled the power from the SEO (special equipment option) fuse. It comes on with the accesories. I also have a to turn it on or off as I please. It looks really clean.
Old Nov 3, 2005 | 01:10 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Pics?
Old Nov 3, 2005 | 10:03 AM
Coban's Avatar
i will get some later today of mine.
Old Nov 3, 2005 | 01:57 PM
stone150's Avatar
so i can just tap into o the fuse box? i was just going to go to radio shack and get an extra cable
Old Nov 6, 2005 | 01:15 PM
Coban's Avatar
here are my pics finally, tell me what ya'll think.
The button and LED on the left is for my amp on/off the button and LED on the right is for the radar detector.
Old Nov 6, 2005 | 06:58 PM
thunder550's Avatar
Here's where I tapped the power wire...it's on the driver's side fuse panel, brown wire. Hopefully you can discern that one from the 15 million other taps I have made in that box.
Old Nov 7, 2005 | 11:39 PM
1slow01Z71's Avatar
Wow you have tapped into a bunch of other ****. Which ones did you tap into for your power ground and Ill for your gauges. Since I know my headunit colors I jsut tapped into the power/ground/Ill behind the headunit and not tap into the fuse panel but I need to redo it and do it right.
