Problem With Lights !!
Old Apr 18, 2007 | 12:05 PM
GTOsRamairSilverado's Avatar
ill check all my fuses later on today and see if thats the problem. if not ill try another stereo. ill update yall later.
Old Apr 18, 2007 | 12:45 PM
spoolin5.3's Avatar
I had a similar problem with my 2000 Sierra. My interior lights completely shut off when the headlights were turned on. Turns out I had a faulty dimmer switch. Could possibly be your problem too.
Old Apr 21, 2007 | 07:27 AM
viciousknid's Avatar
Where's the Beef?
If you have fuses that constantly go out, its because there is something wrong with the wiring. Fuses are the middle man between the electronics and the power source, making sure **** doesn't hit the fan an short circuit your equipment. If you have a fuse that pops constantly its because you either have faulty equipment or bad wiring.
Which is why I suggested checking the fuse and then checking the wire.
Originally Posted by viciousknid
You may want to double check all the wires tho just in case. My wiring eventually gave out.
If the fuse is blown it COULD be a bare wire, if not then its most likely hardware.
It could be in the lights, dash, alarm, horn, or radio from my understanding of that specific problem. correct me if i'm wrong of course, mine was old and they've done alot of changes.
Old Apr 21, 2007 | 09:07 PM
budhayes3's Avatar
PT's Slowest Truck
If I were to guess, I'd be leaning towards the dash light rheostat or it's circuit (dimmer switch)...
Old Apr 23, 2007 | 11:40 PM
from what ive checked im starting to think it might be the dimmer switch like you are saying, cus none of the fuse are bad and ive checked my wiring and from what i can see it look to be in good shape. Now i just have to find a dimmer swith to see if thats the problem.
Old Apr 24, 2007 | 03:38 AM
Where's the Beef?
Never thought of the dimmer switch.. I'll check that on my blazer when I get it back together. Right now its got all kinds of wiring glitches going on and that could very well be why.
Idryfly5
Sep 2, 2022 08:55 PM
MA$TER_E
Sep 9, 2015 03:14 PM
custm2500
Sep 8, 2015 05:53 PM
BIGD4504
Aug 19, 2015 07:57 PM
Ketis
Jul 23, 2015 12:37 PM
