Power wire routing options?
Old Jan 5, 2010 | 03:33 AM
Striped02WS6's Avatar
12 Second Club
Default Power wire routing options?
I am in the middle of installing new kenwood door speakers, kicker pillar speakers, and amping both of them....the amp is small and i will only be running a small power wire to the battery...
my question is where do i run it? Am I going to have to drill or is there a grommet somewhere easy? Thanks alot.
mike
Old Jan 5, 2010 | 05:07 AM
FERGHOE's Avatar
what is this going in? Im assuming a T/A? drivers side firewall has a decent factory gromet you can run it through.
Old Jan 5, 2010 | 01:27 PM
12 Second Club
sorry i forget im on a truck site now....its going in a 2005 Silverado 4X4
Old Jan 5, 2010 | 02:36 PM
thunder550's Avatar
High on diesel fumes
I deleted your other thread, in the future please start just one. You don't need two identical threads in different sections to get an answer.
There's a grommet on the driver's side below the brake master cylinder that will work well. I had a 1/0 gauge power wire running through it for awhile.
Old Jan 5, 2010 | 02:59 PM
Mangled03gmc's Avatar
Baltimore Whore
I went right through the grommet where the main wire harness comes out of the fire wall, under the brake/master cyl are..
Old Jan 5, 2010 | 09:50 PM
12 Second Club
Thanks for the replies fellas..
I was looking around under the dash for this grommet, and I honestly can't see the one to which you're referring under the master cylinder. A bar comes off the back of my brake pedal, and goes into a grommet, but it feels like it more than likely runs straight into the MC itself.
That being said.. HELP.
Thanks again,
Mike
ARC
57
Feb 21, 2022 10:54 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Nimoryan
Jul 5, 2015 03:50 PM
