Power antenna? How to install?
Old Oct 24, 2006 | 01:10 PM
10RamSport's Avatar
Formerly 08_gmc_slt-08/20/2010
Default Power antenna? How to install?
So, just wondering how I can install a power antenna in my truck and have it work with my stock radio? What wires do I splice into? Has anyone had any experience with this?
Thanks!
Old Oct 24, 2006 | 01:58 PM
TXsilverado's Avatar
good luck with that one...
Old Oct 24, 2006 | 05:20 PM
Taylorkdt's Avatar
you can easily wire it to come on with the ignition but the stock radios don't have a power antenna outputwire that I am aware of. If it is base you can use the amp turn on and the antenna will be up only with the radio on.
Old Oct 25, 2006 | 04:55 PM
budhayes3's Avatar
PT's Slowest Truck
Sounds easily doable if you can get your hand on a schematic...maybe find a schematic from a different model GM that has a power antenna. Find out what wire powers up or grounds when the radio is turned on, and tap into that wire to trigger a relay that will control the antenna motor.
thunder550
Oct 8, 2015 04:53 PM
BIGD4504
Jul 28, 2015 11:46 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
