Possible Problem
Old Mar 23, 2006 | 06:05 AM
Default Possible Problem
I finally broke down and replaced my stock H/U with a alpine CDA-9855 (for those considering the change, the stock speakers sound way better with an aftermarket deck).
The Problem:
I also bought infinity KAPPA60.7CS 6.5" components for the front and REF6412CFP 4x6 plates for the rear. Sales guy told me the front's were 2 ohm but I never thought about the back's. I looked it up and they are 4 ohm. Will this screw up the deck if I have 2 different ohms? Also, how will the deck work with the 2 ohms, I read a review and the person said his alpine H/U (no model) that kept cutting out. Should I amplify the fronts, or will the H/U be ok to power them? ditch the rears (or use H/U power for them) without causing damage to any of the stereo components?
TIA
Gerry
Old Mar 23, 2006 | 06:37 AM
RedChevy4x4's Avatar
The components will end up with a 4 ohm load (2 ohms tweeter and 2 ohms woofer). You shouldn't have any problems running them off the H/U.
Old Mar 23, 2006 | 08:24 AM
9GMC9's Avatar
The Problem:
TIA
Gerry
I also am wondering about that, I heard most HU's are 4 ohms, I wanted to get the Infinity Kappa 63.7i and the Infinity Kappa 462.7cfp and both are 2 ohms, will it work or not?
Old Mar 23, 2006 | 11:04 PM
why dont you run a 4 ch amp to the speakers they will sound alot better.
Old Mar 24, 2006 | 06:14 AM
the cost factor. I was looking at the kicker zx200.4 though. Might find out tomorrow what ones worth.
Old Mar 24, 2006 | 09:20 AM
krambo's Avatar
Its all about the wiring... Youu can make it a 2ohm load if you need though.
Old Mar 25, 2006 | 12:22 PM
how? Will it make enough of a difference to make it worthwhile?
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
