Please suggest inexpensive car alarm.
Please suggest inexpensive car alarm so I can keep my stuff.
Recently installed a new audio sys. In my RV van. Then added The cheap kind of alarm that no-one pays attention to. I liked the idea of it being separate an not spliced into my GM vans wiring.
I’ve connected it a few days ago seamed ok. Until yesterday I cranked my TA up it’s rear facing the front of van trigger the siren, TA was 10’ away from the van. the siren is mounted in front of van next to battery.
The alarm must be very sensitive but if I can’t crank the TA near the van I’ll need a better Please suggest inexpensive car alarm.
The alarm must be very sensitive but if I can’t crank the mildly cammed TA near the van I’ll need a better alarm. Pls suggest a decent alarm. thanks
I don't mind spending more just want it separate from any of my GM wiring, no splicing into OEM harness.
I'm leaning toward this $41. alarm certainly has more reviews compared to the turd alarm.
I'll probally have to hide the 12VDC socket so it can't be sean an unplugged.
If you want it to work properly and do it's job it's gotta tie into the electrical system. If done properly theres no reason to worry about it especially on such an old platform. Ive got several trucks still I put vipers and cliffords in 20 plus years ago. Two of the trucks i've replaced the alarms just for newer remotes better range. point when done right theres 0 to worry about.
viper clifford pretty much any DEI branded alarm is all good stuff.
does it sound normal for car triggering the alarm even 10' away? thanks
hows this https://www.amazon.com/Viper-3100V-1...%2C396&sr=8-10
Just buy a Spot trace and you will never have to worry about where your van is again. They can easily be setup to alert you if the vehicle moves and report location and every 2 minutes. I have one on everything I own. Cheap insurance, if someone steals my truck I’m not calling the law I’m going to go get it with a pound of flesh. The law enforcement is more concerned with not violating a criminals rights so much they are causing as much caious as the criminals themselves.
