New Steering Wheel, Is It Possible?
Old Mar 25, 2008 | 06:58 PM
BLUES MAN's Avatar
The House is Rockin'
Default New Steering Wheel, Is It Possible?
i have a 2000 silverado and i want to change the stock steering wheel for something with some more grip like a grant wheel, but mine has a air bag
and im not sure if i can even put one in? does anybody have some advice, or has done this
Old Mar 25, 2008 | 07:04 PM
00Silv4.8's Avatar
Im pretty sure u can do it, u just wont have an air bag. I wouldnt worry about it anyway, onlything a steering wheel bag is for for is a broken nose and/or airbag burn on ur forearm(s). But maybe someone has more input
Old Mar 25, 2008 | 07:26 PM
nightrunner's Avatar
Mr. Obvious
you will have an airbag light on in the cluster, but im pretty sure that if you get the right adapter, it will work.
Old Mar 25, 2008 | 09:24 PM
00Silv4.8's Avatar
cant u turn off the airbag light as well?
Old Mar 25, 2008 | 09:44 PM
Mr. Obvious
i think the only way is to pull the bulb for it
Old Mar 25, 2008 | 10:47 PM
BLUES MAN's Avatar
i was taking a look at the wheel and it looks like i might need a special tool to take it off anybody know?
Old Mar 25, 2008 | 10:54 PM
LowBlack99's Avatar
You could ohm the airbag wires and the solder in a reisitor of the proper value to fix the light. You might need a puller to remove the wheel or try backing the nut off and tapping it with a hammer a few times, don't remove the nut all the way just leave it on a few threads and hit the nut then give the wheel a few hard pulls, with the nut still on so it stops and you don't hit yourself with the wheel.
Old Mar 26, 2008 | 01:53 AM
Shahnp1's Avatar
It can be done. I have a billet specialties steering wheel in my truck. I had a friend at a dealership turn my bags off for me so i didn't have it go off in my face while removing the wheel. I would suggest getting a steering wheel puller from a local parts house that way you dont screw up the steering column. The last one i bought cost $15 i think. I have had mine for about 6yrs with no problems so far just don't have any airbags.
I didn't need any special tools. except the a standard wheel puller. i used a small screwdriver to release the tabs holding the airbag in place on the wheel. theres two small openings on each side of the wheel kind of behind where your hand would be if u place them at at 9 o'clock and 3 o'clock. sorry for the weak description but maybe it will help.
Old Mar 26, 2008 | 02:36 AM
RandomHero's Avatar
My buddy almost bled to death and spent 3 weeks in the icu when his forehead hit the steering wheel in a head on collision. They said an airbag would have GREATLY reduced his chances of severe injury.
So yea I guess they are useless
Old Mar 26, 2008 | 08:03 AM
10RamSport's Avatar
Formerly 08_gmc_slt-08/20/2010
Have you seen this?
http://www.stylintrucks.com/parts.as..._prod_ids=5926
