Need help choosing pillar gauges?
Old Sep 25, 2007 | 06:39 AM
BlueDevil's Avatar
Default Need help choosing pillar gauges?
Hey yall,as some of you know i installed a blower lately. Now im in the market for some gauges for the a-pillar.
I picked up a AFR by autometer at AutoZone (do i really ned it? is it a wrong one?)
...also picked up a Vac/Boost 30psi by autometer at autozone(is this right?)
dont i need a fuel press 100psi gauge as well?
Please post direct links to the correct gauges as i think i picked up the wrong ones and im having a hard time not knowing which ones i need.
Thnx,Mick.
Old Sep 25, 2007 | 05:19 PM
nightrunner's Avatar
Mr. Obvious
wideband AFR digital
http://www.autometer.com/cat_gaugede...id=3604&sid=11
fuel pressure 0-100psi
http://www.autometer.com/cat_gaugede...id=3121&sid=11
boost/vac
http://www.autometer.com/cat_gaugede...id=3125&sid=11
http://www.autometer.com/cat_gaugede...id=3126&sid=11
either boost gauge is ok, just the 15psi doesnt have as wide a sweep as the 30psi one
i used ultralite series as an example
a narrowband AFR is unnecessary and completely useless IMO
http://www.autometer.com/cat_gaugede...id=3083&sid=11
Old Sep 29, 2007 | 03:15 PM
BlueDevil's Avatar
boost/vac
Thanx for the reply
I isntalled the pillar and gauges but i have a few dumb questions...
-Do i replace the existing 02 sensor with the one provided by the dual band?
- Also.....The fuel pressure 100psi electric i have....the sensor wont connect to the fuel rails. There both males. Im assuming i need an adapter?
Old Sep 29, 2007 | 05:02 PM
Mr. Obvious
replace one of the stock rear 02s with the wideband, i think. i see in your sig where you have gibson headers(shorties), im assuming you still have cats and rear 02s hooked up so im not sure. i know on apps w/ Lts/no cats you can replace one of the rear 02s because they arent used and are turned off in the tune
dantheman1540
Feb 24, 2016 09:56 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
sTNT971
Sep 26, 2015 04:22 PM
zblee
Sep 17, 2015 07:58 AM
kmcn47
Sep 17, 2015 01:12 AM
