need dvd/cd help pls
Old Apr 5, 2009 | 12:13 PM
blkonblk's Avatar
Default need dvd/cd help pls
So i bought a new dvd/cd player for my 03 silverado its the JVC KD-AVX40 but the place i bought it from say the harness they have is defective and after giving me the run around i finally said *** it ill buy it from somewhere else. did you guys have any problems with the harness's you bought for the 03's? where did you guys end up buying yours from and finally did you do the install yourselves or is it better to just pay them to install it. i have installed other decks in my other trucks but is it that much hasel to install THIS deck?
Old Apr 5, 2009 | 05:02 PM
RST's Avatar
RST
are u needing the harness that comes with the chime? well i have two silverados and i installed a 7in flip out and it aint hard at all samething as any other deck.I found a harness/chime at walmart for thirty buck its a cheap one but it does the job like an expensive one.
Old Apr 5, 2009 | 08:25 PM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
depending on the truck & what system your vehicle had you might need an axxess box they range anywhere from 80 - 150 not hard to wire though quite simple
GXPJAY
Feb 13, 2022 08:15 AM
GXPJAY
Nov 5, 2015 06:49 AM
dhpro
14
Jun 1, 2007 03:20 PM
