LS SWAP harness
Old May 10, 2018 | 06:41 AM
fakky's Avatar
Registered User
Thanks Fastbrick.
So I think that brings us back to this right ?
2004 Vortec PCM Pinouts
The pinouts should mostly be the same .... but
1) How would i know if a wire position changed - like 36 was no longer fan it was transmission VSS.
2) How to know what is added/different
My only goal is to lay it all out and dewire the main harness bundle to streamline it and add it to a 3 wire setup like
https://www.bp-automotive.com/produc...i-24x-engines/
then I will remove VATS etc via HP Tuners.
Just for a cleaner install. Don't want to remove something that I will need.
Old May 11, 2018 | 02:13 PM
fakky's Avatar
Registered User
Bump-idity
Old May 12, 2018 | 02:08 PM
fakky's Avatar
Registered User
From a guy in another forum he said that you can use that pinout and its pretty basic.
Just remove the pins noted.
Leave the others in place.
Old May 13, 2018 | 05:11 PM
fakky's Avatar
Registered User
Side note.
What do most people do with large draw accessories like the FANS/AC - seems like they run them as a seperate circuit with the main harness.
Controlled by PCM ?
JeRM82
Dec 24, 2012 01:54 AM
MOTTRHED
Oct 21, 2012 06:21 AM
350SS
Apr 9, 2011 03:06 PM
oldred95
Mar 31, 2011 12:44 PM
