locked radio
Old May 30, 2012 | 09:51 AM
skinny chicken's Avatar
Default locked radio
I have a 2003 chevy with the 6 disk changer that quit working. i swapped the radio out with one out of another truck and its locked. i googled how to unlock it but it will not display the codes with anything i try. anyone know a way to unlock it.
Old May 30, 2012 | 05:18 PM
camcamaro1991's Avatar
Post
The radios are VIN coded to each vehicle, you must have the dealer or someone with a Tech 2 unlock it.
TEMPORARY BYPASS INSTRUCTIONS
You can temp bypass this for testing purposes by turning off the truck, then put the key in the ACC position, and pull the
radio fuse for 5 seconds (with the key still in ACC position). Then put the fuse back in and the radio will have full functionality until you
turn the key off or try to start the truck. If you do either of those, the radio will lock up again. Alternatively you can simply unplug the large 24-pin radio connector for 5 seconds instead of pulling the fuse.
Old May 30, 2012 | 05:44 PM
Thanks alot!!! Looks like I need to find a tech 2 close to me.
Old May 30, 2012 | 08:46 PM
TXSZ66AVLANCHE's Avatar
A tech2 alone will not work. also need a subscription to tis2web for programming.
Old May 30, 2012 | 08:50 PM
Well that's shitty news. Looks like I'm buying a new head unit I'm sick of messing with it.
Old May 30, 2012 | 09:12 PM
Or you can take to dealer and pay $60-90 for programming? Cheaper than a new radio...
Old Jun 1, 2012 | 12:29 AM
Post
Most dealers charge $50.00 to unlock a radio, if they hit you up for more, stick it to them.
Alco
Jul 20, 2016 04:53 PM
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
Cammed4ever
Sep 30, 2015 03:38 PM
JoshH
Sep 28, 2015 11:19 AM
