Laptop is down Hard, need advice
Old Nov 21, 2005 | 07:12 PM
moregrip's Avatar
what a rush!
bump!
any laptop dudes around here?
Old Nov 21, 2005 | 09:46 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Might try tech I asked over there in the Racers Lounge about some computer troubles and BAM!! 30 mins later I had about 10 replies and fixed it right up.
Old Nov 22, 2005 | 08:59 AM
fluxu8's Avatar
If it's just a screen, I'd hook it up to a network(preferably yours), access the drive, and pull all your data off, just to be safe. That is, if you don't have to enter a password to logon to the laptop.....you'll be able to start it up without the display.
I've replaced motherboards on laptops, so if it's the screen, it's replaceable. CompUsa is a waste of your time & money...if you can turn a screw driver & be perceptive to where everything hooks up, you're golden.
Old Nov 22, 2005 | 09:38 AM
three83's Avatar
You should be able to hook an external monitor to the laptop. This would tell you if it is the video card or the LCD Display that is bad. I've changed just about every part on Dell Notebooks arlready and it isn't very hard, just have to be careful not to break any of the plastic parts. If you need any help PM me.
Old Nov 22, 2005 | 10:10 AM
moregrip's Avatar
what a rush!
thanks!
external monitor works fine with the laptop when hooked up. I removed the LCD screen and LCD screen inverter board yesterday. Found a shop in CA that sells them for $350. But I cant fine the LCD inverter board anywhere.
How do I know if its the the LCD screen, the LCD inverter board, or both?
Old Nov 22, 2005 | 11:03 AM
three83's Avatar
What is the Make and Model of your laptop?
Old Nov 22, 2005 | 11:04 AM
moregrip's Avatar
what a rush!
Hewlett Packard zd7140us
Old Nov 25, 2005 | 09:52 AM
moregrip's Avatar
what a rush!
update:
well it looks like the problem can be one of 3 things
1. The motherboard - least likely - and the last I will replace
2. LCD screen - more likely, however. I'm told when these go out they usually stay black instead of showing colors.
3. LCD screen inverter - most likely - based on the way it stopped working this is what I will replace first. Ordered it Wed, $100 shipped, hopefully that's the problem.
Thanks for your help
Old Nov 26, 2005 | 05:09 PM
Tractionless's Avatar
Originally Posted by fogle04
if you have to buy a new one i would get this. its the new hotness
http://www.livedigitally.com/theldb/Very%20Old.jpg
I know what I want for christmas.
Old Nov 30, 2005 | 03:53 PM
moregrip's Avatar
what a rush!
still waiting on the cotton-pickin LCD inverter, should be here early next week, this has taught me a lesson though, get the damn warranty with a laptop!
