Jw how to wire and set up?
Old Apr 1, 2013 | 11:14 PM
darnie's Avatar
Default Jw how to wire and set up?
i was just wondering how i should wire up these subs and tune them with this amp, i have both in my truck and wanto get it as close as i can to what it should be set at.
Street Duty SDC2.5-12-D4 Subwoofer
Audio Savings | MEMPHIS AUDIO 16-PRD1.1000 WATT RMS MONO CAR AMPLIFIER
i currently have them set up for the top picture. but i havent been running them yet.
http://www.rockfordfosgate.com/rftec...2&woofer_imp=3
Old Apr 2, 2013 | 12:29 AM
TexasSteve's Avatar
You will have to look at your JVCs stereo diagram & see if it provides a Subwoofer only output or see if you'll need to run a crossover to eliminate all but the low frequencies from reaching the Subwoofer.
Old Apr 2, 2013 | 08:20 AM
darnie's Avatar
as far as off the deck? if so this is the deck im running
Clarion U.S.A. | VRX775VD
Old Apr 16, 2013 | 09:21 PM
jbancs's Avatar
if you want to properly set your gain you'll need an oscilloscope. As for the subs, wire the voice coils in parallel, and then the subs in parallel. That will yield a 1 ohm load to that memphis amp which is rated to deliver 1000 watts rms to the pair.
wrb002
Aug 31, 2015 12:00 PM
Sexyrado327
Aug 2, 2015 04:08 PM
01sierraon22s
Jul 8, 2015 11:26 AM
