Interesting issue with new setup
Old Jun 27, 2018 | 09:19 AM
madmann26's Avatar
Default Interesting issue with new setup
Alright fellow audio listeners. I need some help.
For the past 3-4 years, I've been running the same setup without an issue.
1. Clarion single din cd player
2. Coaxials in the front/rear
3. Amp single 8in sub on the passenger side rear under the seat.
Father's Day, I treated myself to an upgrade.
1. New DD head unit (touchscreen)
2. 6.5 component front/rear
3. Amp for the components
4. Same amp/sub setup from above
Now, the issue.
From the time the radio comes on, there is this whine/hum that I cannot get rid of. In the course of my troubleshooting, I have done the following:
1. Swapped RCA. L to R, F to B and even 2 new sets.
2. Put the original CD player back in, still does it.
3. I verified that my component wires are not exposed/grounding out anywhere.
The fun part....
Without either of my amps ground wires, when I connect the RCAs, the amp will power on. That's right, the RCAs are acting as a ground.
I emailed Richard (Atomic) last night and I have a suggestion from him (THANKS!!).
I do have a homemade big-3 upgrade using 4 gauge cables.
Thanks everyone.
Old Jun 27, 2018 | 05:29 PM
00pooterSS's Avatar
Double check the quality of the amp's ground wire and where it's connected to the vehicle. I see a lot of not so good grounds for amps.
Old Jun 28, 2018 | 01:07 PM
Nick99Chevy's Avatar
Where and how are the amps mounted? Where are your "big 3" connections?
Old Jun 28, 2018 | 01:11 PM
madmann26's Avatar
I put an amp rack in, MDF. They are screwed to that. I pulled my seat out.
Big 3
1. Alt to batt
2. Batt neg to frame
3. Block to frame
(it did this without the above as well)
Old Jun 28, 2018 | 03:17 PM
00pooterSS's Avatar
And the ground for the amp?
Try this as a quick test, use jumper cables and connect them to the battery ground and amp ground wire and see if it stops.
Old Jan 19, 2019 | 04:23 PM
slowness's Avatar
I have the same issue, but all I did was replace the factory speakers and installed a single din BT stereo. it whines with rpm's for me and when I push mute it stops.
Old Jan 20, 2019 | 11:24 AM
Atomic's Avatar
I have a gauge for that
Not sure if he ever got it fixed, but I usually run a ground wire from the crossmemeber behind the radio to the case of the radio itself and that always seems to fix it.
Old Jan 20, 2019 | 01:57 PM
madmann26's Avatar
I tried that as well, didn’t work.
I ended up using a set of RCA noise filters that helped a ton. I can faintly hear it sometimes but I really have to be paying attention.
Quik
Aug 4, 2007 10:22 AM
Yelo
20
Aug 29, 2003 04:32 PM
