install instrument cluster
Old Aug 8, 2007 | 10:01 AM
hawaii50's Avatar
Default install instrument cluster
hi guys..i finally bought a new instrument cluster for my '03 sierra...now how do i install it? is this something i should take to the stealership to do for programming? help me out pls. btw yes i searched
Old Aug 8, 2007 | 10:03 AM
Nick™'s Avatar
being that you are in California, there's a place called Speed-O-Tach in Concord that can program the mileage for you, it's real simple and can be in about 15 minutes with no experience, but the mileage swap is the only possible issue.
Old Aug 8, 2007 | 10:14 AM
hawaii50's Avatar
dayummmm i called about 4 dealerships now and they all quoted me $300+!!! is this the normal price or is it socal markup??
Old Aug 8, 2007 | 10:18 AM
hawaii50's Avatar
honestly, i just want to know how fast i'm going. is it possible for me to just install it myself now, and reprogram it later? i just dont see the justification for all of this for a stupid flaw in our GM trucks that have not been recalled
Old Aug 8, 2007 | 10:22 AM
hawaii50's Avatar
i think i might just sell the cluster for dirt cheap and live life without knowing how fast i'm going.
Old Aug 8, 2007 | 10:24 AM
Fogle07's Avatar
you can put it in but it will start with 0 miles. it will work fine just your miles will be wrong. take your dash bezel out and theres 4 screws that hold it in. pull it out unplug, plug new one in and put it back together
Old Aug 8, 2007 | 10:26 AM
willymac's Avatar
you can hook it up and it should work and just look at reprogramming the mileage later, just write down the original mileage to keep track of it
Old Aug 8, 2007 | 10:34 AM
hawaii50's Avatar
so just to clarify because i'm slooow...i write down the miles that are on there now...swap the old cluster for the new one, and it should be able to tell me how fast i'm going right? also, i can go for as long as i want like this, then if i decide to reprogram it later, they'll just add up my current mileage to the miles i wrote down before the swap?
Old Aug 8, 2007 | 10:37 AM
hawaii50's Avatar
btw, the MOST, not all, but most of the service guys i called at the dealerships were such A-holes about it...like, they were pissed because i couldn't install it myself or something. my fault for not being good with auto electronics. like i have the equipment to program an instrument cluster myself!
Old Aug 8, 2007 | 10:41 AM
Fogle07's Avatar
yea if you decide later to reprogram just add the mileage together and they will put that mileage on there.
everything will work fine youll just have zero miles. speedo, fuel, battery, oil, everything
