I need a Nelson E-fan harness instruction ASAP
Old Dec 21, 2007 | 11:20 AM
moregrip's Avatar
what a rush!
Default I need a Nelson E-fan harness instruction ASAP
trying to wire the ground function now, thanks
Old Dec 21, 2007 | 11:30 AM
flossinon_24s's Avatar
Ive got mine, but wont be able to scan them till around 5:00 PM CST
Old Dec 21, 2007 | 11:35 AM
moregrip's Avatar
what a rush!
thanks, thats better than nothing, really need one now though
Old Dec 21, 2007 | 11:49 AM
thunder550's Avatar
High on diesel fumes
Do you just have the single ground wire that goes to the PCM?
Old Dec 21, 2007 | 11:59 AM
chuckie311's Avatar
check your pm
Old Dec 21, 2007 | 12:01 PM
moregrip's Avatar
what a rush!
thanks, how do I wire the switched ground feature?
Old Dec 21, 2007 | 12:27 PM
bluecajun5.3's Avatar
11 Second Truck Club
your talking about adding a toggle switch to control the fans manually?
if so get a 2 prong toggle switch. (mine is 50amp, don't know if it needs that much).
one wire is going to tap into the wire that goes to the pcm and the other is going to go to a ground.
Old Dec 21, 2007 | 01:32 PM
moregrip's Avatar
what a rush!
hmm, thats not what I mean, there is a way to have the pcm trigger, a/c trigger, and manual trigger
Old Dec 21, 2007 | 02:44 PM
Nick™'s Avatar
the way that blue cajun described will create a manual fan on (both fans on low) using a ground wire.
you tap the wire going between the pcm and the rest of the original fan harness, then run that to a switch, the other wire from the switch goes to ground - simple as that, when you flip the switch you will ground the same wire that the pcm grounds when the truck gets to turn on temp.
Old Dec 21, 2007 | 02:46 PM
moregrip's Avatar
what a rush!
so as long as it recieves a ground, either manually or pcm the fans will come on?
