high beam/low beam relay kit issue
Old Mar 16, 2010 | 02:09 PM
00DzrtSlvrado's Avatar
Registered User
Default high beam/low beam relay kit issue
I have a 00' Silverado with HID low beams and stock high beams for the time being. I recently purchased a "high four" relay kit so I can use all four factory headlights when the high beams are clicked over. However...this kit doesnt like to work with HIDs. It makes the HIDs flicker while turning on the high beams (in essence you can tell the kit is working, but the HIDs arent getting the power they need now). I saw a guy who simply used a 12 volt diode and jumped from one relay to the other in the fuse block under the hood. BUT, his truck was an 07' and the fuse block is different than mine (00') does anyone have the slightest clue as to what two relays to go between with the diode, or an idea to solve this issue? thanks
Old Mar 16, 2010 | 02:26 PM
nonnieselman's Avatar
You got to wire it up differently. that kit is made for Halogen bulbs.
Ill let ya know how mine is setup wheni get home.
Old Mar 17, 2010 | 05:08 AM
Parke10's Avatar
i think on the 2000 you just cut a wire under the dash and ground it out..i cant seem to find the thread, but someone should chime in with it.
Old Mar 19, 2010 | 01:18 PM
Registered User
okay thank you. any help on this is awesome.
Old Mar 20, 2010 | 01:39 AM
larsy87's Avatar
apple bottom jeans
When I did the 4 hi mod I just cut the yellow wire and grounded it out on some sheet metal...don't know if that'll work with HIDS.
that yellow wire
LCHEE
Oct 24, 2020 04:10 PM
Bluchevypick
Aug 18, 2015 09:11 AM
lo&sloSierra
Jul 19, 2015 04:21 PM
lo&sloSierra
Jul 19, 2015 10:56 AM
slowlsx
Jul 13, 2015 04:18 AM
