help on shift light!
Old Jan 9, 2006 | 09:40 PM
GREENMILE's Avatar
Default help on shift light!
i just ordered a proform shift light from jegs and i was wondering if anybody knew how to install one.
Old Jan 11, 2006 | 05:53 PM
DakotaKiller5.3's Avatar
Default Yes I got it too
hey i bought the proform light too. it is ALOT bigger in life than it looks in a magazine. i am going to assume a few things before i say this...
1. i ASSUME this is the dial operated shift light (no pills/modules)
2. i ASSUME your truck is a 99-2000 4.8/ 5.3/ 6.0
3. i ASSUME this is the same application as mine
take the power wire and find a 12v source with the ignition on (mine was a 12-14ga Green wire in fuse panel) then take the ground wire, ground it out to a good clean surface (to the left side of fuse panel was a nut securing the dash to fire wall.. worked great) and hook the ign wire to the white wire on tach cluster ( mine was tan, from the 4 yrs of smoking.) to ensure it is the right ing wire... you can take the plug off the PCM use PIN 10 and check continuity through to the plug on the instrument cluster. i did that, and it worked for ME. when all that is hooked up the 2 small wires on the light( they make a small loop) i believe they were orange and brown... cut them and cap them off so they dont short out on anything. dial it in and blind yourself.
anyone else got anything i forgot?
JFortner5
Aug 19, 2015 02:44 PM
stock48
11
Aug 18, 2015 05:55 AM
Ferocity02
Aug 7, 2015 08:50 PM
Ketis
Jul 23, 2015 12:37 PM
