Help me diognose electrical problem.
Old Jan 15, 2006 | 01:16 PM
FILE's Avatar
Default Help me diognose electrical problem. (FIXED)
This is on my wife's 01 Sierra. I was at the track this past Firday night and took off the passenger side headlight. After putting the passenger light back on, the lightbulbs light up very dim. This is for both high beam and low. This is the weird part. When the passenger lights are connected and and in low beam, the high beam bulb are lit as well but very dim on both sides(passenger and driver's side). This does not happens to the driver's side when the passenger's side is disconnected. BTW, the lightbulbs are perfectly fine as I have tried them on my truck.
Old Jan 16, 2006 | 04:53 AM
budhayes3's Avatar
PT's Slowest Truck
Sounds like a ground issue...I'd check and make sure that none of the wires got accidentially partially broken or backed out of their connectors, etc.
Old Jan 16, 2006 | 11:51 AM
moregrip's Avatar
what a rush!
agree, or some old/damaged wire
Old Jan 16, 2006 | 12:52 PM
Fogle07's Avatar
you sure you didnt plug them in backwards
Old Jan 27, 2006 | 06:34 PM
FILE's Avatar
After getting pissed by not finding anything wrong with the wiiring I decided to check the fuses... Bingo.. Problem stolved.
drummer0415
11
Oct 24, 2015 08:16 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
dantheman1540
Sep 15, 2015 08:28 PM
Pimpinpete
Sep 8, 2015 07:39 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
