help me decide on a sterio
Old May 2, 2011 | 12:24 PM
AndysC3's Avatar
Default help me decide on a sterio
ok, I recently bought a 97 jeep Cherokee from a friend. It has no stereo or speakers. its going to be my daily driver so I don't want to cheap out. I'm looking at a nice Pioneer hu and speakers. I have a sealed box with 2 10" Rockford Fosgate R1's rated at 300 150rms. Looking for a amp that will match the speakers. But all of these numbers are confusing the crap outta me. What amp would you use?
Old May 2, 2011 | 07:28 PM
gtosilverado's Avatar
well, get an amp that is rated for at least 300rms.... but how many ohms are each of your subs ??? if they are 4 ohm, you need an amp thats rated 300rms or slightly more (400 or 500) at 2ohms mono
Old May 2, 2011 | 07:37 PM
AndysC3's Avatar
each sub is rated @ 4 ohms
Old May 2, 2011 | 07:47 PM
Kemble's Avatar
Ive got a kicker 550.3 that works out great. Powers one 10" sub and my front components. Its a class a/b amp and a class d in the same amp
Channel 1 + 2 RMS Power Rating:
4 ohms: 70 watts x 2 chan.
2 ohms: 85 watts x 2 chan.
Subwoofer Channel RMS Power Rating:
4 ohms: 210 watts x 1 chan.
2 ohms: 420 watts x 1 chan.
Old May 3, 2011 | 02:39 AM
AndysC3's Avatar
thats what i mean about all the numbers. confuses the crap outta me. i have two Rockford Fosgate r1's.
Impedance: 4-Ohm
Voice Coil Diameter: 2.0" (4-Layer) (3.8cm)
Motor Size: 51.57 oz.(1.46 Kg.)
Speaker Connector: 12 AWG compression
Fs (Hz): 24
Re (Ohms): 3.35
Le (mH): 2.1
Qts: 0.38
Qes: 0.42
Qms: 4.39
Vas (Liters): 87.7
Sd (cm2): 330
SPL (1w/1m): 86
Xmax (mm): 5.8
Woofer Displacement: 0.024 cu. ft.
(0.69 Liters)
Cutout Diameter: 9.13 in. (23.20 cm)
Mounting Depth: 4.57 in. (11.60 cm)
looking for an amp to run both subs.
Old May 3, 2011 | 07:20 AM
Sc00by's Avatar
Pick up a 400 - 500 watt mono (single channel sub amp) and forget about it. A JL500/1 would pound the hell out of your 10's but can run about a $1 a watt ($500 new). Definatly try to over power your subs vs. under powering them. Think of it this way......Towing a decent sized boat with your truck with the 4.3l 6cyl vs a 6.0l 8cyl. The 6cyl will work its *** off trying to pull the boat at speed where the 6.0l will pull it with ease. If you put a 250watt amp up to your setup it would work its *** off trying to play the speakers at volume vs. a 500 watt slightly over powered amp which would handle your setup like a walk in the park.
For simplistic reasons the only specs you need to worry about are:
Impedance: 4-Ohm
RMS: 150 watts
Peak: 300 watts
The other specs are used for box design, and to give a person a little information on how a speaker is going to perform. It can be complex so I wouldn't worry about it.
Let us know how it sounds!!!!
Old May 3, 2011 | 01:56 PM
You cant over watt them. A large amp that is fed a clean signal and oversized wont kill a sub because it is putting out a clean un clipped signa. The amp and your subs will live a long healthy life because you don't have to abuse the **** out of it to get the beat you want.
A undersized amp that is pushed hard with the gains cranked like most people do is a sub killing amp. It does this because it is putting out a dirty signal to the subs. It is called a clipped signal the subs will try to reproduce this nasty signal until they kill themselves.
For what you are wanting to run something like a JL audio 500/1 at 2 ohms will work perfectly.
Old May 5, 2011 | 07:51 PM
u can also go with a rockford fosgate power500.1bd , it will push around 400rms to those subs, more than enough
Old May 14, 2011 | 10:06 AM
AndysC3's Avatar
ok, I got a deal on two RF R150-2. 150rms @ 4 ohms bridged each. Should do the trick. the wiring is going to be fun.
Old May 14, 2011 | 10:20 AM
00ChevyScott's Avatar
Wearin' da big hat
You're going to run 2 2-channel amps just to make 3-400 watts???????????????? Seems like a stupid idea to me.
