HELP with head unit mounting
Old Nov 30, 2009 | 12:26 PM
colekill's Avatar
KickinAssAndTakinNames
Default HELP with head unit mounting
ok i just got a pioneer deh-p3100 and the metra99-2003. and i cant figure out how to mount the stereo to the kit.
wires are not a problem. just the actuall mounting of the unit please help!
http://www.metraonline.com/products.aspx?s=99-2003
link to the metra kit with the instructions which make no sense to me.
Old Nov 30, 2009 | 12:29 PM
zachm89's Avatar
it should slide in from the front and there should be some little metal tabs on the head unit itself that you flip out with a flathead screwdriver to hold it in place. for my pioneer there were two on the top and bottom and one on each side. hope this helps!
Zach
oh yeah, almost forgot...i didnt have to use any of the extra brackets that came with the metra kit, so if you dont see a use for them they probably arent needed for your vehicle. those kits fit a very wide variety of cars and trucks so they have to include the extra crap for all of them.
Old Nov 30, 2009 | 12:42 PM
colekill's Avatar
if i dont use anything the steros *** sags and it could easily just slide in and out
Old Nov 30, 2009 | 03:10 PM
zachm89's Avatar
hmm, those metal tabs should prevent it from sliding out. im assuming that the metra kit mounts solid to where the factory radio was screwed in, its just the head unit that is still lose in the dash kit? if so, you may have to figure out one of the brackets to use that came with the kit. only thing i can think of without seeing it would be one of the brakets may screw to the side of the metra kit and hold the head unit up in the rear.
Old Nov 30, 2009 | 07:34 PM
Black'Rado's Avatar
is it a double din or single din? if double din then just use the side brackets and screw them to the sides of the radio and use the trim plate on the front that clips to the brackets if that makes since....if single din lock the radio cage in tight and slide the radio in.. hope that helps u some
Old Nov 30, 2009 | 07:48 PM
zachm89's Avatar
i think its a single din...if i looked up the right one earlier. like i said on mine the metal tabs on the cage around the head unit hold it in tightly...idk why it would be so lose on yours :\
Old Dec 1, 2009 | 01:30 AM
colekill's Avatar
yeah its single din. got it figured out. didnt use any of the stuff that came with the kit just the metal tabs on the stereo.
Old Dec 1, 2009 | 01:31 AM
colekill's Avatar
i've just never properly installed a stereo before.
Old Dec 1, 2009 | 11:22 PM
LaWhite01's Avatar
did u put a screen in that was double din??
Old Dec 1, 2009 | 11:23 PM
LaWhite01's Avatar
oh nvm
