Help with audio setup for my 2005 Silverado Ext. Cab
Old Apr 6, 2010 | 11:49 PM
Kryptic's Avatar
Registered User
Arrow Help with audio setup for my 2005 Silverado Ext. Cab
Hey guys, I'm new to the forums, I actually just stumbled upon this while looking for a box for my truck. Basically I'm wanting to put together a nice setup. Preferably one that wont suck my truck dry, I want to keep what I need to purchase extra to a minimum. Here is some things I want...
DD Head Unit for sure. Bluetooth would be nice, NAV optional
2 - 12" or 2 - 10" Subs (Unsure which to go with to be honest)
Nice amp to put this in
And of course I need a box to handle this all.
My issue is I've really just began my experience with audio, Especially for a truck. If anyone here could maybe put together a scenario and a rough cost. I would appreciate it soo much. I'm going to have this installed locally at a place called Installations Unlimited, I know family and friends have had stuff done there, Seems like they do a good job. Any help or suggestions much appreciated.
Old Apr 7, 2010 | 08:46 PM
KILLDERADO's Avatar
Registered User
do you plan on using the seat in the extended cab?
Old Apr 7, 2010 | 11:53 PM
Kryptic's Avatar
Registered User
Yes, so i figure my only option is a downfire box correct?
Old Apr 8, 2010 | 07:52 AM
Sc00by's Avatar
Subs and Amps: two 10's in a downfire box fit perfect under the seat in an extended cab with out any mods to the back seat. Depending on the subs you decied on you'll probably need around a 500w amp to push things with a little head room.
headunits: Look into Alpine, Kenwood Excelon, Pioneer for you dual din headunit needs. All are great quality companys and have different products to match your price point that you are willing to spend. I know Alpine (and im sure the rest do as well) has a module that plugs into the back of the unit and allows you to keep your steering wheel controls if your worried about that.
Old Apr 10, 2010 | 10:43 PM
Kryptic's Avatar
Registered User
My Setup Thoughts:
HeadUnit: Pioner Avic-x910BT -http://www.amazon.com/Pioneer-AVIC-X...0956672&sr=8-1
Amp: Hifonics Zeus ZXI1010 1000 Watt Two-Channel Amplifier - http://www.amazon.com/Hifonics-Zeus-...0957326&sr=1-6
Subs: Undecided if I want to go 10's or 12's .. I was thinking about doing some RE Audio 12's maybe the SEx series about $169 a piece
Box: 99-06 GM Extended Cab Ultra Deep MAXX Dual 10/12 Downfire Box NEW - http://subthump.com/product_info.php...roducts_id=206
I don't have the steering controls, The reason I chose the Pioneer as a possibility was i didnt have to buy extra modules for Bluetooth/Nav... although I have a garmin already why not have everything built in? I mean I could always sell the Garmin or give it to the parents.
Old Apr 11, 2010 | 11:25 AM
KILLDERADO's Avatar
Registered User
what is your budget after your headunit purchase? have you installed an amp installation kit(power wires, rca/remote cables)?
I wouldnt suggest RE audio. if you look they rate the $130 10" sub at '2000 watts' but in the specs its rated at 300. scroll down and they make an 18" sub that has a peak power handling of 4000 watts/2000rms for $900. a 10" sub that can handle 2000 watts peak is nuts. so basically they have a line of bargain stuff they're trying to hype up so it sells... their competition stuff looks pretty decent, but ive never heard them.
Old Apr 11, 2010 | 03:10 PM
allballz57's Avatar
I have a downfire box with two 10" fosgate's,it was custom built to work under the extended cab seat,but I have also lifted the seat 2".If you want I will sell you the box with subs and seat lift for $200 plus shipping.I want to go a different direction with my audio and was thinking about listing this.pm me if interested and I will get you some pics.
Old Apr 11, 2010 | 03:32 PM
Kryptic's Avatar
Registered User
Here are the ones i was highly considering...
(2) RE SEx 12" SEx-Series Sub (Dual 4-Ohm)
# Dual Composite 2-piece Cone
# Rubatek Foam Surround
# Cast Aluminum Basket
# Tork-Tite Terminal
# 3 " 4-layer Aluminum Voice Coil
# FEA Optimized Motor Structure
# Triple Stack Magnets
# Progressive Spiders
# Wrap around Rubber Gasket
# Mounting Depth: 6.9"
# Mounting Hole Diameter: 11.2"
# Electrical Q Value -Qes: 0.49
# Mechanical Q Value -Qms: 4.5
# Total Speaker Q Value -Qts: 0.44
# Free Air Resonance -Fs: 25.1 Hz
# Equivalent Compliance -Vas: 72.9 liters
# One-Way, Linear Excursion -Xmax: 18 mm
# Efficiency -SPL 1W/1m: 86.1 dB SPL
# Effective Piston Area -Sd: 480 cm^2
# DC Resistance -Re: 2.8 ohm
# Force Factor -Bl: 17.7
* Above specs are per sub (except Power Handling)
Old Apr 11, 2010 | 03:36 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I don't think you'll get those to fit in a down-fire box under the back seat, without somehow lifting the seat and building the box yourself.
Old Apr 11, 2010 | 03:38 PM
Kryptic's Avatar
Registered User
See underlined - this is the box i was considering from SubThump.com mounting of sub shows 6.9" and the box 8"
Fits: 99-06 and 07 Classic GM Extended Cabs
3/4" MDF Construction
Approx. Empty Weight: 39 lbs
Installs under the rear seat
No modifications required
Does not affect rear seat latching
Seat will still go all the way down and latch
Fits 10" and 12" round or square subs
Mounting Depth: 8" (not a misprint)
Volume: 1.13 cu.ft per chamber
Sealed Box, separated chambers
Finish: Carpet
Terminals: Installed
Logo Text: Optional
Subwoofers Sold Separately
