help
Old Jan 3, 2006 | 02:49 PM
$thatguy$'s Avatar
Exclamation help
im using my stock radio and im putting in my amp i got all my wire ran and i bought a converter so i can hook up my rca cables to my amp... now here is the question where do i hook up my remote wire ?
Old Jan 3, 2006 | 03:04 PM
slowprocess's Avatar
Does your converter have a pink wire on it?
Old Jan 3, 2006 | 03:08 PM
$thatguy$'s Avatar
man no it has two in puts on it and then the rca outs
Old Jan 3, 2006 | 03:10 PM
Fogle07's Avatar
hook your remote wire up to the yellow wire. do you have your line converter installed?
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Window Trim
Front Speakers 6 1/2" Doors
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 4" x 6" Side Pillar
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Old Jan 3, 2006 | 03:12 PM
Just find a place in your side fuse panel that is hot when the ignition is on. Basically the same thing as a remote wire
Ground Black
Illumination Gray
Dimmer Brown
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
or what he said.
Old Jan 3, 2006 | 03:40 PM
smooth_addictions's Avatar
yeah you just need a ignition on power source. it doesnt draw that much either. so it can be like a cigerette lighter wire or something like that.
