Headlights Problems
Old Dec 29, 2005 | 07:12 AM
Jeff Smith's Avatar
Default Headlights Problems
I have 2003 DuraMax Diesel 2500HD, had wrecked at front end and reconditioned body.
The headlamp (dimmer) at driver’s side, strong bright and passenger side, weak low. When I turn high beam switch is same as dimmer headlights.
I found the two grounds (-) attached onto frame beside at under front left bumper. What wrong with it?
Have you experinced with that situation? I need your help to solve with it.
Thanks for feeding back...I appreciate it
Old Dec 29, 2005 | 07:45 AM
KySilverado's Avatar
Has to be either voltage or ground. Put a meter on the hot side and check voltage. Run a wire directly from the grounds up to the negative side of battery to test the ground. I found mine dimming a bit and the chrome behind them was actually getting a haze on them that washed off. Are they the same bulbs from side to side? Since it was a rebuild? Just suggestions.
Good Luck
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
