Headlights Problems
I have 2003 DuraMax Diesel 2500HD, had wrecked at front end and reconditioned body.
The headlamp (dimmer) at driver’s side, strong bright and passenger side, weak low. When I turn high beam switch is same as dimmer headlights.
I found the two grounds (-) attached onto frame beside at under front left bumper.
What wrong with it?
Have you experinced with that situation? I need your help to solve with it.
Thanks for feeding back...I appreciate it
What wrong with it? Have you experinced with that situation? I need your help to solve with it.
Has to be either voltage or ground. Put a meter on the hot side and check voltage. Run a wire directly from the grounds up to the negative side of battery to test the ground. I found mine dimming a bit and the chrome behind them was actually getting a haze on them that washed off. Are they the same bulbs from side to side? Since it was a rebuild? Just suggestions.
Good Luck
Good Luck
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
