factory subwoofer
Old Jun 23, 2007 | 10:58 AM
00yukon22"'s Avatar
Default factory subwoofer
i have a 00 yukon with a factory sub and there are only two wires running into it, i was wondering if i can just unplug those from the factory sub and run them into the speaker level inputs on my aftermarket amp?
also where would i run the remote wire from, im keeping the factory head unit.
thanks for the help
Old Jun 23, 2007 | 07:57 PM
optikalilution's Avatar
in my old AV i tapped into the wires from the factory bose amp to the sub (4 wires) and used a line level converter to hook up to the amp, the remote wire i found a fuse in the fuse panel that comes on with ignition and off when off. buy tapping and not removing the wires i at least had the factory sub when i needed to remove the others. it was a GREAT setup, if you have any Q's pm me and i will answer them to the best of my knowledge, i have the color codes on the wiring from the bose amp if you need it.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
CD82
Oct 23, 2015 07:32 AM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
Closer_2001
Sep 24, 2015 09:15 PM
