Factory Bose Stereo has no sound
Old Nov 4, 2009 | 09:02 AM
12 Second Club
Default Factory Bose Stereo has no sound
Started the Yukon this morning heading to work, and no sound...no FM stations, no XM, no CD...no sound what so ever....do the speakers run on their own fuse or does this sound like something more than just that?? haven't had time to look at the fuse block, so just wanna get some input on what to try and look at to fix this...
thanks in advance
Old Nov 4, 2009 | 09:03 AM
charcoal03silvy's Avatar
The head unit itself is working though right?
Old Nov 4, 2009 | 09:08 AM
Dewey's Avatar
check the fuses and the back of the radio, the harness may be loose but i'm pretty sure the bose speakers run on the same amp as any other factory speaker.
Old Nov 4, 2009 | 01:34 PM
12 Second Club
display is working fine, just no sound.
Old Nov 4, 2009 | 02:01 PM
SSlammed03's Avatar
if the radio turns on its not the fuse... maybe they amp took a $hit.. the amp is on the bottom of the center console
Old Nov 4, 2009 | 02:32 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Some of these can be corrected with a reflash using Tech 2. Check with your dealer. There used to be a TSB, probably still is.
Amp failures are not uncommon....
Old Nov 4, 2009 | 08:40 PM
53bowtie's Avatar
I thought the bose systems had a seperate fuse for the head unit and the amp?? I am pretty sure the last trailblazer I worked on with bose had a "radio amp" fuse.
Corvette454l88
Sep 1, 2016 01:24 AM
mzoomora
Jan 3, 2016 07:06 AM
gaps
Oct 15, 2015 02:53 PM
thunder550
Oct 8, 2015 04:53 PM
gaps
Sep 2, 2015 01:19 PM
