Electrical problem??
Old Jan 13, 2009 | 05:29 PM
One_Slow4.8's Avatar
Default Electrical problem??
hey. Everyone what's up I haven't been on in awhile. But anyways there is some kind of short in my electrical system at night my head lights dim and the gauges dim as well. my system is not huge or anything so anyone have. Any clue??
Old Jan 13, 2009 | 07:10 PM
jaegmc99's Avatar
did you say they dim @ idle or when you letoff the throttle?
Old Jan 13, 2009 | 07:21 PM
larsy87's Avatar
apple bottom jeans
check the voltage off your alternator at idle, see what it says...give it cruising revs and see what it says(get a buddy lol)
Old Jan 13, 2009 | 07:30 PM
I was testing it last night and it would go to 3-4 lines passed 14 volts right after every wot shift but while it was wide open it was 3 lines below 14 so I'm at a loss
Old Jan 13, 2009 | 08:53 PM
larsy87's Avatar
apple bottom jeans
12.8 to 14 is good....do you have corrosion on your battery terminals? Unhook them and clean em with water and baking soda.
Old Jan 13, 2009 | 09:02 PM
You think it could be a short or a bad ground??
Old Jan 13, 2009 | 09:09 PM
larsy87's Avatar
apple bottom jeans
Actually, disregard my last comment..battery doesn't do anything when the truck is running...still a good idea to clean your terminals though.
Turn your system off and drive around..see if the problem is still there. I was getting dimming off of a 500 watts, on stock electrical.
Old Jan 13, 2009 | 09:34 PM
Ok I will. I found some more stuff out when my ac. Is on and I roll both windows the ac shuts off untill I let off of the switch.
Old Jan 13, 2009 | 09:39 PM
Wilde Racing's Avatar
How do I change this text
Power windows actually draw quite a bit on the system. Everything else works ok in the truck though? does the battery go dead after a few days?
Old Jan 13, 2009 | 10:01 PM
D_reks{5.3}'s Avatar
i only have a JL 500.1 pushin my sub and it makes my **** dim.
