electrical noise
Old Apr 16, 2014 | 01:47 PM
cwalker2006's Avatar
Default electrical noise
I have components in my doors and when I turn up the amp just a little bit it had bad electrical noise. Its done it since I put them in like years ago. Anyone know what's going on
Old Apr 16, 2014 | 04:33 PM
Suburbazine's Avatar
Bad ground somewhere in the speaker system most likely. Check that your amp ground is solid too.
Old Apr 16, 2014 | 04:34 PM
95killerz's Avatar
12 Second Club
I recently out an alpine head unit and ever since I've got static even if the volume is all the way down the static is still clear. Don't mean to hijack just wondering if it could be anything along the same lines
Old Apr 16, 2014 | 05:24 PM
Chevy_King1500's Avatar
do u have an amp? if so are the power wire and RCA cables ran together?
Old Apr 16, 2014 | 05:55 PM
95killerz's Avatar
12 Second Club
My rcas are run seperate of the power wire, I'm also only using the amp for subs still has factory speakers which is where I'm hearing the static
Old Apr 16, 2014 | 08:28 PM
Power is ran on driver side and rcas are ran on passenger. If I keep the amp turned down to just barely on, you can't really hear it. I'll check the ground connections and report back. Where is a good place to ground an amp in an extended cab? It's behind the seat and I think the ground is under the floor trim. Screwed in to cab
Old Apr 16, 2014 | 09:51 PM
You've gotta take a wire brush and remove all the paint at the ground connection.
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
Velocity1
Oct 2, 2015 08:01 AM
tim wellington
Sep 29, 2015 10:17 PM
