Dual Battery Setup
Old Jan 24, 2007 | 09:52 AM
moes04silverado's Avatar
Default Dual Battery Setup
Any know have any knowledge on how to do this....
Old Jan 24, 2007 | 09:55 AM
Dock Rocker's Avatar
pm nonnieselman he has done it
Old Jan 26, 2007 | 01:01 PM
nonnieselman's Avatar
Here ya go... and for anyone else that wants to know.
Yes i took time to draw a Schematic up in Paint ( )
AUX BATTERY tray mounted on the Passenger Fenderwell.
Red Wire (Hot) runs to the engine cover, Under it and comes out in this loom..
Then connects inside the lil red box.
I dont have a pic of where i mounted the Ground for the AUX Battery. But my Paint Schematic Special shows that.
I had enough Red wire left over i ran some from the ALT to the Red Box. Figured it wouldnt hurt to replace the stock 10ga stuff, Or was it 12ga? That stuff is small for sure.
Wire is 6ga Red and Black.
Total cost: ~$80
Battery tray
Battery
Battery connectors
Crimp on Stud connectors
Wire
Zip Ties
Old Jan 26, 2007 | 01:06 PM
Ive gotten too good at pulling out Transmissions on a 2wd unfortunally also..........
Old Jan 26, 2007 | 04:36 PM
a new level's Avatar
PM me if you want some picks of my factory setup.
Old Jan 28, 2007 | 10:10 PM
bigredexpress99's Avatar
Pailess Wiring also has a dual batt setup I used on my 92 and 99 silvy's, and worked flawlessly. Could charge one, both, and use one or both to start the truck. Basically allowed the use of two different batts ( i had one yellow top and one red top Optima).
This is the key thing....if you use the setup like Nonnie used, you need to used 2 of basically the same exact battery, in pretty much the same state of health. The weak one will kill the strong one in the long run much faster.
Old Jan 28, 2007 | 10:20 PM
truckmann's Avatar
I think using an isolator, which the painless system must come with should be a must. It's a good safety measure and if wired correctly you can run one battery down completely and still use the other battery to start the truck. Surly a stock setup comes with an isolator?
Old Jan 28, 2007 | 10:41 PM
laynlow77's Avatar
Old Dec 14, 2012 | 10:29 PM
Ws6Luvr's Avatar
sorry for bumping an old thread, but don't think it requires another new thread...
is this the painless kit I need?
Painless Wiring Part 40120 - Digital Power Manager
Old Dec 15, 2012 | 12:35 AM
jbancs's Avatar
I think he was referring to this kit. Either way, what you're wanting to do can be accomplished for much less money by using something that doesn't say painless.
Painless Wiring Part 40102 - 250 AMP Dual Battery Control
