Custom light wiring
Old Jul 29, 2012 | 08:42 AM
Giterdunn's Avatar
Default Custom light wiring
I've got ccfl halos wired to my marker lights, and they look great, but if I want to run them in the daytime I have to switch my markers on, and that makes my taillights burn during the day. I want to keep them wired to my markers, but I also want to run a jumper wire to the + on my DRL's. That way they will be on automatically during the day and at night. But if i do run a jumper and have 2 different + wires feeding the halo's transformer, the voltage will flow backwards across the jumper wire, so the markers would turn on the DRL's, and vica-versa. My question is what would be the best way to solve that problem, by using relays, or putting diodes inline with both of the + wires? I was thinking diodes would be the simplest, but I don't know what rating I need cause I have no idea how many amps the halo's pull. Has anybody with an amp meter tested there's before? I have a multimeter but it only does voltage and resistance. Also, I have replaced the DRL and marker light bulbs with LED bulbs, and was wondering if anybody knows what rating resistor I need to solve the fast blinking turn signal problem?
Old Jul 29, 2012 | 02:16 PM
jbancs's Avatar
Depending on the amount of current going to the lights, I'm recommend using diodes if you can.
Old Aug 18, 2012 | 10:45 PM
5speedsilverado's Avatar
yeah use diods and jump the 85? pin from the relays. all done in the fuse box like the high-4 mod
ARC
57
Feb 21, 2022 10:54 AM
silver-mod-o
Jul 27, 2015 05:24 PM
carid
Jul 24, 2015 05:00 AM
Ketis
Jul 23, 2015 12:37 PM
