a/c wiring diagram...
Old Sep 13, 2008 | 05:01 PM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
Default a/c wiring diagram...
wiring in some LED's to light up the a/c control unit...what's power what's ground? thanks in advance! oo 2004 GMC Sierra RCSB manual a/c controls
Old Sep 13, 2008 | 10:02 PM
agreif's Avatar
Best way to check is with a multimeter. That's what I did when I put in LED. You can usually see the ground as it ties in to a larger "pool" of ground than the individual strands of 12V
Old Sep 14, 2008 | 05:19 PM
OneQwikSS's Avatar
yeah i just used a test light on the plug & used the ground off my radio...either way...it came out like ****...how did you mount ur led's in there? i drilled holes from the top & dropped them in
Old Sep 14, 2008 | 09:02 PM
agreif's Avatar
Oh, I didn't drill any holes. I actually replaced the regular bulbs with LED's.
Old Sep 14, 2008 | 09:07 PM
OneQwikSS's Avatar
how'd you do that? what year do you have? mine are soldered in
Old Sep 14, 2008 | 09:09 PM
agreif's Avatar
mine's an '01. Yeah, mine were too, desoldered each one....friggen lot of work.
Old Sep 14, 2008 | 09:25 PM
OneQwikSS's Avatar
is it worth it? cause i've got the led's that're just on wires...if i snip the wires & solder onto the board is it worth the trouble? do you have any pics? thanks
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 30, 2015 09:39 PM
