Brake Light Problems
Old Sep 27, 2005 | 06:48 PM
drkblusierra's Avatar
Default Brake Light Problems
I just baught a Sir Michaels roll pan and while wiring the light for the license plate i think i blew a fuse, my problem is now the drivers side brake light (top bulb) does not turn on as a running light when it gets dark but it will light up when i press the brake pedal. Ive checked every fuse i thought would control it with the help of my owners manuel, without any luck. Does anyone know which fuse i need to check that would control the top bulb of the drivers side brake light and/or the stock license plate lights. thanks.
Old Sep 27, 2005 | 09:25 PM
budhayes3's Avatar
PT's Slowest Truck
Sounds like the bulb is bad...it has 2 separate filaments for running lights and brake lights. I'd pop a bulb in it first and take it from there.
Old Sep 30, 2005 | 01:39 PM
yep, changed the bulb and it didnt fix the problem... any other sugestions? maybe since i eliminated the wiring of one of the license plate lights, do you think this could have thrown off some sort of "electrical loop" on the drivers side? thanks.
Old Sep 30, 2005 | 11:08 PM
KennysR6's Avatar
Thats what it sounds like too.... Change the Bulb brother and you'll be fine...
Old Oct 1, 2005 | 11:15 AM
yeah guys already changed it, the light still doesnt work...
Old Oct 1, 2005 | 11:38 PM
budhayes3's Avatar
PT's Slowest Truck
Pretty sure that you should be able to find the fuse that you're looking for under the hood...there's also a fuse panel on the left side of the dash, but I don't think that there's a tail fuse in there. Since you have a new bulb in there, if all of the fuses check out OK, you might have an open wire or faulty socket for the bulb.
Corvette454l88
Sep 1, 2016 01:24 AM
08lambochevy
Aug 14, 2015 07:50 PM
97aztecgt
Aug 13, 2015 02:11 PM
atxlt
Jul 20, 2015 11:06 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
