Big Amp Alternator
Big Amp Alternator
I will soon be running two (2) amplifiers in my truck. One 450 watt Amp will run four (4) door speakers and & 6" sub-woofer and one 500 watt mono amp will run an 8" sub-woofer.
My factory alternator in my '13 GMC Sierra 1500 SLT is 145 amp. I can get bigger alternators that range in amperage of 160-250-300-350. Should I consider something like these bigger amp alternators to adequately run my new stereo system? I will be running #4 gauge cable from the battery to a splitter (1 in 2 out) to two #8 gauge cables, one to each amp.
Your thoughts?
Chad
Your thoughts?
Chad
I put a fat capacitor in my truck. I put in a mdf panel on the back of the cab held in place with liquid nails.
I also increased the size of my ground cables under the hood along with a larger power wire from the alternator to the battery.
I also run 2 amps. 1 4 channel RF and 1 mono amp for the sun.
Unfortunately, that big alternator won't produce anywhere near that amperage at idle RPM. You will need to set a much higher engine speed to produce big power. Otherwise, its coming out of your battery.
Rick
Rick
https://www.crutchfield.com/shopsear...capacitor.html
You size the capacitor based on wattage of the amps.
Found it!!
https://www.rockvilleaudio.com/rxc2d/
You guys are awesome, I would have never thought about this!!
Chad
Chad
I’ve had mine in for a year now without an issue.
ss4chad (04-04-2020)
You are better off putting the money for this big fat cap you speak of into a really nice battery. There are alternator companies that make alternators that actually do well at idle. Power master, Iraggi, mechman...etc. doing the “big 3” plus a really nice battery would be and will be my first move though.
If you buy a cheap "WOO 250A OUTPUT" *peak* alternator... then yeah those are pretty much only putting out their rated spec at mid/high RPM range IF they are even putting out their rated spec. Buy one of the $300+ custom alternators, from names as mentioned above and they will absolutely put out the high amps at idle, which is where it is most useful.
You may want to do a combination of things, of course upgrading factory wiring (Big Three), upgrade to a factory 160A and then a good battery as well, you should be good to go.
grocerygetter (04-05-2020)
