auto dim mirror upgrade
Old Mar 15, 2012 | 09:48 PM
1FSTMAX's Avatar
Default auto dim mirror upgrade
Hello,
I have a 07 silverado classic w/t. The truck was born with no options pretty much, and today I installed an auto dim mirror with compass and temperature.
I know the truck doesn't have the temp probe in front of the radiator, however im wondering if the wiring might be there by any chance. Any help is greatly appreciated.
TIA!
Old Mar 15, 2012 | 10:25 PM
javzh's Avatar
you have to get the temp probe and run the wires to the new rear view mirror with compass and temp.
got this off gmfs
Compass Temp Mirror - Chevy Truck Forum | GMC Truck Forum - GmFullsize.com
this is for the 16pin plug
Pin 1-not used
2 - Microphone (if the mirror is equipped with it)
3 - "Passenger Air Bag on" notification (if mirror is equipped with that display) - ground pin to activate icon
4 - "Passenger Air Bag off" notification (if mirror is equipped with that display) - ground pin to activate icon
5 - auto day/night signal, which comes from the LH outside rearview mirror
6 - Temp probe connection ( if mirror is equipped with display)
7 - Temp probe connection (if mirror is equipped with display)
8 - Ground
9 - After taking a mirror apart and experimenting, I've discovered that pin 9 is common with pin 8 - they are both soldered directly to the ground plane on the circuit board. So, it's a ground.
10 - Microphone (if mirror is equipped)
11- keypad signal (out) for On-star - pressing any button puts out a multiplexed signal on this pin, - so you can't just use the buttons to control whatever you want to. Sorry.
Update - Well, yes you can, if you do a little rewiring (arghh, arghh!). The 3 Onstar system buttons across the bottom of the mirror are rubber covers over membrane-type switches. The switches are actually part of the circuit board itself, but if you're VERY, VERY careful you can use an X-acto knife to cut the traces on the board from the trace ring land on the output side of the switch to the surface-mounted components. Then VERY, VERY carefully solder a small wire from the ring land to one of the unused pins on the back of the wiring connector for each switch (not the power switch, though - leave that one alone.) The input of the switches are all common to the main ground plane of the circuit board, so now when you press any of the switches you'll be sending a ground to whatever connector pin you soldered that switch's wire to. You can use this switched ground to activate the ground side of any relay, thus controlling nearly function on the car by touching one of the mirror-mounted buttons. They are momentary, though, so you'll need to wire in a latching circuit if you want that function to be constant on.
There are also led's under each button which are normally only on whenever that function of the Onstar system is activated - but they can be hardwired to the kepad's 5v supply and grounded from other unused pins on the wiring connector if you want by employing the same rewiring technique above. They could be wired so that they only come on when the vehicle' s dash lights are on so they're easy to find at night.
12 - keypad supply (5v) voltage (in) for the buttons
13 - ignition voltage (12v -main power IN to the mirror)
14 - Green LED signal (to the right of the Emergency button) - apply 12v to light LED.
15 - Red LED signal (to the right of the Emergency button) - apply 12v to light LED.
16 - return line to the LH outside mirror for day/night signal
Old Mar 15, 2012 | 10:32 PM
1FSTMAX's Avatar
thanks! i guess ill run the wires..
Old Mar 27, 2012 | 09:42 AM
Devs93's Avatar
good info javh I may have an extra prob if you want it pay for shipping and its yours
blowngmc
32
Oct 12, 2017 11:59 AM
murderedSS
27
Oct 12, 2015 11:13 AM
bisqikss
Sep 8, 2015 03:35 AM
Stainless Works
Sep 3, 2015 08:31 AM
01 5.3
Sep 2, 2015 02:17 PM
