Audio whine with RPM
Old Jan 19, 2019 | 04:46 PM
slowness's Avatar
Default Audio whine with RPM
So I recently replaced the factory deck with a BT single din, nothing special. And replaced the factory speakers with some kickers. Everything sounds great except for at low speeds you hear a whine through the speakers with increase in RPM. If I push the mute button it stops. this is in an 07 GMT900 w/t rcsb
Old Jan 20, 2019 | 07:27 AM
ILuvJDM's Avatar
Start by upgrading the 12v constant and ground wires to the headunit. Do not use the factory ground in the harness, run it to metal in the dash somewhere
Old Jan 20, 2019 | 12:07 PM
Atomic's Avatar
I have a gauge for that
Yep, grounding the head unit case to the crossmember in the dash behind the radio always fixed this for me.
ridnlow
Sep 5, 2007 10:35 AM
Dragaholic
Mar 24, 2006 06:04 PM
Quikenuf
Dec 25, 2002 10:42 PM
