ATTN: kenwood excelon users
has anyone had any problems out the kenwood excelon series in their trucks? the reason i ask is because mine started flickering on and off and wouldnt stay on for no longer than 15 seconds, i sent it to cructhfield and they re-solderd the j1 connection, i got it back it still did the same thing, my wiring and harness is 100% correct, i sent the radio back, they say they cant find anything wrong with it, they said check the fat yellow wire, its a memory wire make sure its getting 12 volts, its getting 13.89 volts wich should be enough, any ideas?
I have not had any problems out of mine save the ipod reader being slow at times.
I would also check to make sure the red wire(switched power) is getting a full 12 volts as well and that the ground wire is good. You may even run a temporary wire out to the negative terminal of the battery and see if that fixes your problem.
Yah if you can buy that same head unit some where else, buy it, then switch you whole unit out with it, then tell them it didn't fit what you was putting it in.. Problem solved..
I agree on blowing it out, but also check the ground and antenna. I had a stereo that used the antenna as a ground as well and wouldn't work unless it was in there good. You didn't splice any wires did you?
heres the deal with it,,i bought it along with a ton of other stuff from crutchfield, ive had it for i dont know about 3 months, it worked fine until it started flickering on and off and really pissing me off especially when i have brand new subs and speaker i cant even get the best out of cause of this f'ing radio, i got the harness that you have to wire in a bell chime, my truck is an 03 no onstar or any of that bull, while my radio has been gone for the second time and crutchfield constantly telling me its fine, ive had my factory one it and it works like a charm, just no subs or anything because im not puttting a rca box back in, so pretty much crutchfield is tellin me to eff off because they cant find anything wrong with it and every time i have to talk to them i get some goob saying "are you sure you have a full 12v to everything?" then me"yes i have 14 volts to everything" then they tell me well your harness must be messed up somewhere. So anyways the last i talked to them i told them if i get my radio back and it doesnt work im taking every harness(engine,fog lights, head lights, tail lights, dash, everyfreaking one imagineable) in my truck out and sending all of them so they can check them.
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Superman09
Sep 25, 2015 05:55 AM
