amp started blowing fuses
Old Aug 22, 2007 | 10:14 AM
Default amp started blowing fuses
I have 2 10's powered by a 1000watt amplifier. There is a 40amp fuse on the amplifier and a 100amp fuse spliced into the power cable which sits in my engine bay. The 40 amp is the one that keeps blowing. It only happens when I run about 85-90% bass for 5+ minutes. Is this normal, or is something wrong here? I don't normally run that much bass at any given time and I'll probably turn the amplifier down a few notches anyways.
Old Aug 22, 2007 | 11:25 AM
larsy87's Avatar
apple bottom jeans
What is the impedance of the subs and how do you have them wired?
What kind of amp? There's a chance your running the amp at a lower impedance then it can take and that's why your popping fuses.
And as a tip, you can tell your amp can't put out 1000 watts.
14.4V(input voltage) * 40A(fuse rating) = 576 watts
There's a little bit of variance in this but it's usually close to correct, it's a good way of telling if amp ratings are bogus or not.
Old Aug 22, 2007 | 01:33 PM
I'm not too smart when it comes to systems, so you're gonna have to work with me a bit. I don't know what impedance is or how to find it. I have the subs wired for 4ohms. It's a Kenwood amp.
Old Aug 22, 2007 | 01:40 PM
larsy87's Avatar
apple bottom jeans
Impedance = ohms
I still think they might not be wired correctly. If you could find the model number of see if the impedance is on the sub, it would be a great help.
Did it just start doing this or have you had the amp in for a while?
Old Aug 22, 2007 | 06:40 PM
I've had the system in the truck for about three months now and it just started. I'll try to find the model number later.
Old Aug 22, 2007 | 08:06 PM
larsy87's Avatar
apple bottom jeans
Toss that then about impedances.
Have you recently adjusted the gains, or changed some settings in your head unit?
Old Aug 22, 2007 | 11:00 PM
txredxj's Avatar
you should also get a smaller fuse under the hood. 60 or smaller.
Old Aug 23, 2007 | 06:44 PM
Yeah, I changed the settings on the amp a bit. After it started screwing me over, I set them all back to where I had them before. Everything has been fine for a few days now.
This is the amp I have.
http://www.kenwoodusa.com/products/L...k3=155&pr=2719
Old Aug 23, 2007 | 06:51 PM
larsy87's Avatar
apple bottom jeans
It's most likely you clipped the amp, and blew the fuse. If it's back to where it was and s working fine, you'll be allright.
Your bass boost is off, right?
Old Aug 23, 2007 | 07:11 PM
I don't think so. Is that bad?
