alternator amps?
Old Oct 25, 2007 | 08:00 PM
53bowtie's Avatar
Default alternator amps?
how many volts does your alternator put out?
i just upgraded my alt. wire to 0ga. and it does about 14.7 volts goin down the road, is this too much? with everything on (a/c, stereo, headlights, etc.) it still puts out around 14.4 to 14.5......TIA
Old Oct 25, 2007 | 10:03 PM
04BlackGmc's Avatar
10 Second Club
ok your label is off..
you asked amps but explain voltage..
but anyway yes that is good thats what my tahoe alt puts out..i have the big three uprade tahoe alt and yellow top.
also puts out 160 peak amps. funny thing is that its only rated at 130.
Old Oct 26, 2007 | 01:01 AM
ramdaspadhye's Avatar
110a at idle, 200a at 1600 rpm's. Does what I need it to do. I'm only pushing 1500 watts RMS, so I don't have a terrible voltage drop. With my stock alt, voltage dropped sometimes while sitting in gear, DEFINITELY with the AC on. Since I've upgraded, I have yet to see a voltage drop.
Old Oct 26, 2007 | 08:32 AM
53bowtie's Avatar
what alt. do you have? i was thinkin i might just get a 145 but now i am thinkin maybe i need a 200a if there is only 110 at idle.....
Old Oct 26, 2007 | 08:34 AM
53bowtie's Avatar
my bad...........i was thinkin about my recent wire upgrade at the same time i was thinkin about upgrading my alt. and mixed the two.......
Old Oct 26, 2007 | 11:16 AM
budhayes3's Avatar
PT's Slowest Truck
You're talking about the wire that goes from the little red box to the B+ terminal of the alternator correct? Just curious, did you put an inline fuse in that wire? From what I've read, the factory B+ wire also serves as a fusible link for circuit protection in case of overcharging/excessive current...something to consider...
Old Oct 26, 2007 | 05:58 PM
04BlackGmc's Avatar
10 Second Club
correct, would have doubled the wire up and ran that wire from the+on the battery to the back of the ALT.
Old Oct 26, 2007 | 07:56 PM
53bowtie's Avatar
there is what i did....100A fuse....straight from the alt to the battery terminal....
Old Oct 27, 2007 | 01:07 AM
I have an iraggi alt
Old Oct 27, 2007 | 12:39 PM
budhayes3's Avatar
PT's Slowest Truck
Very nice, I like it
