Airbag powered stereo!
Old Mar 21, 2008 | 04:12 PM
Wyttrash96's Avatar
I hate my cats
Default Airbag powered stereo!
Just figured out why my 8 inch powered subbox wouldn't work even though I KNEW I had power to it. Turned out I didn't have the remote lug wired. Duh. I didn't want to always have the subbox powered, so I pulled the dash fusebox panel and found a green wire that had keyed power. Tapped into it, and now my airbag light is on. Is the green wire the power wire for the airbags? If so, I'm a COMPLETE DOLT, cause I've got my stereo wired into my airbag circuit. If not, can my airbag light be figured out and turned off with HPT? Thanks.
Old Mar 21, 2008 | 06:38 PM
95 bright teal's Avatar
id go under the kick panel below the stearing column and run it to the orange wire if you want it only to be on when the truck is on(what i did) or to the pink wire which is the accessory wire
Old Mar 22, 2008 | 10:17 AM
53bowtie's Avatar
i strongly second this oppinion.......
Old Mar 22, 2008 | 10:41 AM
dewmanshu's Avatar
Moderately Differentiated
If you have HPT, what codes are you getting?
Just find another wire (as mentioned), put the other back how you got it. If you have HPT just reset your DTC's. I wouldn't suggest trying to kill that light, just get things back to normal.
Old Mar 22, 2008 | 12:41 PM
Wyttrash96's Avatar
I hate my cats
I'm actually not sure if I got any DTCs, none of them looked like an airbag code anyways. Ya, guess I'll have to just put the remote wire to another source. Oh well. Thanks for the replies folks.
Old Mar 22, 2008 | 01:22 PM
LowBlack99's Avatar
Air bag circuits are usually identified by having Yellow connectors on the ends, the wires can be any color. By tapping onto the airbag circuit if you did it will set the light because airbags work off of resistors, thats why you can find the resistance then add a resistor and disconnect the airbags if you don't want them. So by tapping a airbag wire you have changed the resistance, this could cause your bags to either not work or work when not wanted. Now as for how to fix it?? well that my be better done by the dealer as just removing the "tap" it may cause airbags to deploy. If you choose to try to do it yourself be sure and unhook the battery for a couple mins. to allow the airbag system to discharge, it stays powered with the key off in the event you were in a stranded vehicle that was hit.
Old Mar 22, 2008 | 07:34 PM
Wyttrash96's Avatar
I hate my cats
Hmmm, that's some good info. But now it makes me think that it was either just a coincidence or I nudged an airbag wire when I tapped into that green wire. Cause I hooked into that wire when my test light told me it was keyed power. Ya, I'll unhook the battery cable just to try to reset the airbag light, but I sure as hell don't want that **** going off when I'm working right around it. If that don't work, it's off to the dealer for me. Yay. Thank you for the great info.
Idryfly5
Sep 2, 2022 08:55 PM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Superman09
Sep 25, 2015 05:55 AM
muncie21
Sep 7, 2015 09:55 PM
