Adding a battery
Old Feb 25, 2009 | 07:45 PM
One_Slow4.8's Avatar
Default Adding a battery
thinking about adding one of those high powered cells to my electrical system. i would like to put in the secondary battery location. could i hook it up like this?
apologize for the crappy drawing but im not a skilled paint artist
Old Feb 25, 2009 | 08:56 PM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
lol dude i'm confused what are you asking...how to wire a second battery in?
Old Feb 25, 2009 | 09:15 PM
viciousknid's Avatar
Where's the Beef?
Are you wanting another battery or a capacitor. or both?
Consensus says that a Capacitor isn't worth it. and unless your running a bunch of insanely huge amps, you only need 1 battery. just do an alternator mod or the big 3 and move on.
You should be good enough if you just add in an extra wire from the battery to the alternator.
Old Feb 25, 2009 | 10:06 PM
OneQwikSS's Avatar
x2 i mean caps do help but not worth all the aggrevation when the big 3 & altenator mod only takes a few hours and you end up spending about the same amount...
Old Feb 25, 2009 | 11:32 PM
oh no i wasn't thinking about a cap i was talking about the kinetic batteries and i was wanting to put it in the factory d max location. and wire it in so it would charge and stuff but ya i was wanting to do the big 3 but to be honest it kind of scares me because of the write up says good luck and hope it starts..... kinda makes me feel uncomfortable ha ha
Old Feb 25, 2009 | 11:49 PM
Where's the Beef?
LOL. that's only because if you don't get a good connection on the grounds it won't start. Just make sure you clean them up real good and get them tight and everything is fine.
Old Feb 26, 2009 | 08:20 AM
OneQwikSS's Avatar
yeah it's just like wiring up a system if you don't have a good ground...the amp will turn off...if you don't have a good ground to the battery...truck won't start...either way kinetics are overpriced IMO unless you're running 3-4 amps you can still run a Optima & you're fine
Old Feb 26, 2009 | 08:07 PM
53bowtie's Avatar
I would recommend an isolator between the two batteries so they dont equalize when the vehice is off.
Old Feb 26, 2009 | 08:30 PM
Wyttrash96's Avatar
I hate my cats
What is the Big 3? Did a search, can't find anything.
Old Feb 26, 2009 | 08:41 PM
Where's the Beef?
Go into the Stereo & Electronics section. On the top right click Search This Forum and try again.
Should be the 2nd result you get.
