12 volt switched 2010 silverado
key on 12 volt switched. adding amp, stock head unit. i know there isn't a 12v switch at the head unit, or the fuse box on the drivers side.
column perhaps? any idea's would be nice.
Kind of a blurry picture, took it before I knew my camera had a macro feature... Should be able to see where to put the wire though. Its under the little square cover to the left of the brake pedal.
in the box that smokeshoe showed in that pic under the dash, should be a green, or grey plug on the left side and it should have a few small pink wires coming out of it i believe. 1 of those should work. but there so small you might have to run a relay just to be a safe side
I was going to say, I know there is a prong in the fuse box to the left of the brake pedal that is tied to the vehicle RAP system. That's where I have mine ran to with the exact setup that was mentioned.
cams 98 silverado
Jul 31, 2015 07:36 AM
Offroadunleashed
Jul 20, 2015 02:25 PM
