01 Tahoe Head Unit Swap Questions
Old May 28, 2008 | 10:49 PM
11secondhorse's Avatar
Default 01 Tahoe Head Unit Swap Questions
ive got a 01 tahoe lt without Bose but with Onstar and i want to change the head unit out to something better but not sure if i can just plug and play. it has a bunch of speakers so i was thinking it might be like my trans am and have amps built in that make the stuff 4ohm instead of 8ohm like everything else aftermarket.
is this true or can you just yank out the unit and pop in an aftermarket player?
it has the tape deck down below the cd player thats tied into it, would you just unplug it?
also its 1.5 DIN size right?
any help or links would be great, i want to do a system soon.
Old May 29, 2008 | 10:51 AM
ok so im guessing that NOBODY has replaced the stereo in thier trucks huh? i thought the main point of this site was to get help with projects from people that have done them?? apparently not..
Old May 29, 2008 | 10:55 AM
cmb570's Avatar
im not a stereo buff. My friend usually hooks me up. But unless you have the bose system you can just upgrade the head unit. You can also remove the cd player below and put a pocket in its place from chevy. Only the bose system is integrated with amps and everything.
Old May 29, 2008 | 10:58 AM
thunder550's Avatar
High on diesel fumes
If it has Onstar it's not a direct swap. I tried to swap head units in my mom's 2000 Suburban and I got no sound from the speakers. She ended up taking it somewhere, so I'm not sure what exactly they did, but I know it involved disabling Onstar.
Old May 29, 2008 | 06:07 PM
ok so i better dig around a little more before just trying to slap something in here lol
Old May 30, 2008 | 11:11 PM
flossinon_24s's Avatar
use a pac os-1. its the onstar adapter
Old May 31, 2008 | 11:36 AM
BigKID's Avatar
If you have the rear sub, you will have an amp behind the glove box that will have to be delt with. If you want to add and aftermarket head unit, you will need an adapter that converts the high level out puts from the head unit to low level into the amp. Or else you can just re-wire everything yourself as I did. An OnStar adapter is a waste of money as yours is no longer functional.
btw... I almost didn't post this due to you shitty attitude in post #2. This is an internet forum, not insta-answer. You need some patients or do some research yourself.
Old May 31, 2008 | 05:07 PM
ajt86's Avatar
call crutchfield up- they have some awsome customer service, and you tell them what you have- they will make sure you have everything you need for the install- it might end up costing you 50$ extra in the end, but you wont be running back and forth to the store because you find you need somthing else
Old May 31, 2008 | 07:31 PM
i guess i gotta find out exactly what im working with, if its gonna be a hassle i may just replace the internal speakers too and re-wire em.
and calm down "bigkid" i was being a smart *** not an *******
D1SCSS
Jan 25, 2016 10:14 PM
Ketis
Jul 23, 2015 12:37 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
blownss27
Jul 20, 2015 08:59 AM
