01 Gauge Cluster Lights
So I just replaced my 01 Silverado gauge cluster with a Denali one to get the higher speedo and trans temp gauge. But now the parking brake light and high beam light won't turn on in the dsah. The check engine light does turn on like it should but the driver seat belt light lights up but only half of the icon. Turn signals and everything else works fine. I plugged my old cluster in and everything works fine in the old one. I have swapped light bulbs and installed them both ways as well. I can not figure out why the parking brake and high beam light won't turn on in the dash with this new cluster. Any ideas? Or just a bad cluster?
They are both the 00-02 clusters. I don't know if the pin outs are the same they should be I don't see anyone else saying you have to move pins around. What I can't figure out is the driver seat belt light is half lit. Looks like it's cut in half diagonally. Turn signals are fine. I think ABS light is fine can't tell because I don't have a ABS issues.
I found this picture it looks like there are a lot more light bulbs on the top of the gauge then the back of the circuit board shows. The smallest of the bulbs you can't replace from the twist locks on the back of the board I bet it is these bulbs that have gone out. I will take mine apart and see how this plays out and will update the thread. Thanks everyone
