Sponsor's Announcements, Sales, and Specials This is for our site sponsors to make announcements
RPMSpeed Sales Thread Pt2 (cams and rockers)
Old 08-18-2017, 02:49 PM
Truck Sponsor
RPMSpeed Tech's Avatar
Default RPMSpeed Sales Thread Pt2 (cams and rockers)
The thread a few have been waiting for!! This is related mostly to valvetrain, cams, and install kits.
RPMSpeed HD (new) rocker arm kits with upgraded neddle bearing trunions. First off therr are a few points about these rocker arms i will address.
1. Avail in cathedral port and rec port confgurations
2. Avail with or without our 12.9 allen head cap screw bolts
3. Comes with 2 packets of zddp moly assembly lube, more avail for a little extra (8 oz pack)
4. These are brand new rockers not used stock upgraded. They are assembled for us by melling. That way precision is insured and no install issues creep up. They DO use C&U needle bearings. C&U is a leading global company for bearings and their facilities are located in China mostly. So yes they are chinese bearings. We did not source the parts of the kit so its not our decision as to where to source what. The rocker is gm and the trunions are made here. The trunion material is a 5120 steel with 100% thru core heat treat with rockwell hardness of 59.
5. We had the trunions sent to an outside lab to test for surface finish/smoothness, chemical structure/type of seal, hardness, depth of heat treat, and structure. All of the info surpassed our expectations. We can get you any extra info from that youd like.
6. I am currently putting a set through a 3000 mile test on my own 6.0 in my 2500hd truck. They will be pulled this weekend. (8-18)
7. The trunions are not avail separately
Now for the actual info...link here
How much? Well before we tell you that, lets let you know what is included!
Kit includes
16 rockers
16 grade m8x1.25 socket head cap screw bolts
2 packets of ZDDP assembly/break in lube
Actual pic
PRICE? $230 Shipped.
When will they ship? These will ship out EVERY FRIDAY. We have about 40 sets on hand right now in both cathedral layout and rec port layout (offset intake).
For any other info or questions etc i can start a separate tech thread to answer all of that and keep the for sale thread clean.
CAM KITS
We offer so many cam kits from nearly all the companies, but we have a few signature cams we will post here. Ourn2 cams th High Lift Hot cam and the High Lift ASA cam use brand new lobes we developed in conjunction with Texas Speed.
Both were made to be true BUDGET cams. They use pac1218 or 1219x springs (or any dual spring) and can use stock pushrods OR upgrade to our RPMSpeed 7.400 pushrods for a little extra
RPMSPEED HIGH LIFT HOT CAM - info here with video and dyno graph
Great sound and great power! Easy on the valvetrain, valve guides, rocker arms, and quiet under the hood.
RPMSPEED HIGH LIFT ASA CAM - info here sorry no dynos yet
We will be developing more cams soon as well. We also sell all TSP and BTR cams. We keep btr dual spring kits and tsp dual spring kits on hand also with the new 1 piece easy install seat/seal
PT.net members get the High Lift Hot Cam or ASA cam kits for $500 shipped add pushrods for $565 shipped! Normally $515 and $580.
Cam install kits - more complete than the competitors
Our cam install kits come in 3 different levels
Basic kit $37.99 shipped
Front cover gasket
Front cover seal
Water pump gaskets (97-98 fiber and 99+metal/oring)
Crank bolt
Oil pump o rings (red and blue)
Basic + Kit - $51.99 shipped
Front cover gasket
Front cover seal
Water pump gaskets (97-98 fiber and 99+ metal/oring)
Crank bolt
Valve cover gaskets with bolt grommets
Deluxe kit - $77.99 shipped
Front cover gasket
Front cover seal
Crank bolt
Cam thrust plate
You can also add ls2 chain, complete timing set, oil pump, or upgrade to arp crank bolt as well for extra.
Special package pricing for complete kits or mix and match!!
Email rpmspeedtech@gmail.com or pm me for more info!!!!
Thanks guys
Old 08-21-2017, 04:36 PM
Resident Retard
BlackGMC's Avatar
What brand gaskets are used in you gasket kits?
Old 08-21-2017, 04:42 PM
Truck Sponsor
Dana/Victor Reinz and some that are made specifically for us.
Old 08-24-2017, 05:19 AM
speedracer2536's Avatar
any kits for the gen 5 trucks?
Old 08-24-2017, 11:19 AM
Truck Sponsor
We are working on that! Will let you know.
Old 08-24-2017, 04:07 PM
Truck Sponsor
Believe it or not, there are not alot of gaskets on the gen5 engines.
No real front cover gasket, oil pan gasket, or rear cover gasket.
We have the rest of the gaskets avail though and will package them with any of the gen5 cams you can get from tsp or btr etc. We do not have a cam we are working on for th gen5 engines yet. I will post info soon on the pricing!
Old 08-29-2017, 11:58 AM
Truck Sponsor
Thanks for the sales guys! all pms, comments, emails and vms replied to!
Old 08-31-2017, 03:06 PM
Truck Sponsor
Thanks for the sales guys!! all pms and emails answered
Old 09-11-2017, 12:18 PM
Truck Sponsor
Sale is going on all the time!! save time searching and shipping get it all at once place!
Old 09-14-2017, 10:35 AM
Truck Sponsor
These sales are on all the time.
Thanks guys
