Sponsor's Announcements, Sales, and Specials This is for our site sponsors to make announcements
New inter cooler kit. 3,4,5" set ups.
Old Apr 24, 2014 | 08:36 PM
  #21
Choda's Avatar
Originally Posted by cwalker2006
I have your previous intercooler kit. Is this one an improvement over the old? It mounts in the frame
Exactly. I have a stage 2 kit and was thinking the same. But I gotta say the fmic that came w the kit looks so badass in my grill.
Old Apr 25, 2014 | 10:11 AM
  #22
Will's Avatar
I am not trying to on your thread, but I am curious.
What is the difference in your intercooler and something from like CXracing?
I mean $900 versus about $300 for intercooler and piping seems like a very big difference for just a custom fit kit.
If I am way off here, just set me straight....
Old Apr 25, 2014 | 03:38 PM
  #23
blownescalade62's Avatar
Just ordered the 5" kit for my new build from Rick.
Old Apr 25, 2014 | 09:33 PM
  #24
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by LsF-150
What would be the "general" rule of thumb for the different sizes as far as hp or cfm are concerned? At what point would a 4" be an improvement over 3" and 5" over 4"? Will the larger set up hinder spool time any?
Large core will not hender spool rate. Unless theres a slow spool rate already.
Conservatively I wouldn't go to the 4" unless well past 800hp.
5" until past 1500.
Adding meth injection changes everything.
The thickness adds a good amount if flow area.
These cores
3"- 69
4"- 92
5"- 115
Give you an example current 99-07 standard cores
3"-33
4"-44
Year 08-13
3"- 36
4"- 48
Yes but only if you need it. Running 10-12 psi on older set ups the intercoolers that went out with kits are fine. Pushing 18+ these larger cores will be an improvement. The older bumper mount cores worked but weren't in the direct air flow like these are.
Bumper under core support intercooler we use to use had
42" of flow area.
think yours is behind the grill so your cooling is better then the older ones. It will help if your boost is hi and air temps are hi.
All my oversea customer demand large front mount intercoolers
But the outside air temps are 114+ on a mild day.
Great. What's the application?
We understand these cores don't fit everyone's builds. That's ok.
We take great pride in building the best parts for these trucks we can.
These intercoolers are no exception.
We designed these cores to be the largest cores you can fit in these trucks.
2x as large as other cores on the market. And that's the 3" core.
There are four mounting brackets holding these units in place.
Two are mounted hi to the hood latch area.
Two are mounted to the lower core support.
All the aluminum pipes are cut to length and bead rolled. No need to buy extra piping that don't come in universal kits.
All silicone couplers are 5 ply and black for a clean factory look.
The silicones are matched to the application.
So if your using a 2.5,3.0,4.0 compressor discharge, we will swap the coupler and clamp to match. No extra charge to you.
Kits are set up for mass air meter. No need to buy other silicones or pay freight back n forth while you figure out what sizes work.
If you run speed density: no problem. Just tell us so we can swap couplers around and extend the tubing to the proper length. SD kits also gets an air temp bung welded in. No extra charge. No running around town
To find a welder to take care of this.
SS tbolt clamps are matched to the couplers.
BOV is a compact 50mm design with the flange already welded in place.
Old Apr 25, 2014 | 10:42 PM
  #25
5" until past 1500.
These cores
3"- 69
4"- 92
5"- 115
3"-33
4"-44
Year 08-13
3"- 36
4"- 48
42" of flow area.
2011 Escalade EXT
Brian Wall should have placed order for the kit. I'm the guy that bought Marks big Turbo kit.
Old Apr 26, 2014 | 08:08 AM
  #26
Choda's Avatar
Thanks for the explanation and always coming out w bigger and better truck stuff.
Old May 26, 2014 | 06:04 PM
  #27
shifty89's Avatar
Who makes the cores?
Old May 26, 2014 | 06:16 PM
  #28
Got the 5" kit installed its huge! Nice quality thanks Rick!
Old May 26, 2014 | 06:39 PM
  #29
Choda's Avatar
Post some pics
Old May 26, 2014 | 08:07 PM
  #30
Post some pics
Cant its got bumper back on it. I dont even have any pics of my build.
