Gears, Posi's, Lockers, Bearings, Axles, More!
#561
#562
Ok, sounds like an 11.5.
Here are some links:
*GM 11.5 4.56 Ring and Pinion USA Standard Gear Set ZG GM11.5-456 - Ron's Machining Service
AAM 11.5" Rearend Dodge & Chevy Master Install Bearing kit R11.5RMK - Ron's Machining Service
Chevy & Dodge AAM 11.5" Helical Gear Posi Differential YP PC11.5-HELIC - Ron's Machining Service
GM 9.25 IFS 4.56 Ring and Pinion Motive Gear Set G895456IFS - Ron's Machining Service
1999-2010 GM 9.25" IFS Chevy Front Master Install Bearing kit R9.2RIFSLMK - Ron's Machining Service
Please let me know if you have any questions.
Thanks, Ron
1-800-694-3098
Thanks, Ron
1-800-694-3098
#564
Thanks, Ron
1-800-694-3098
#565
I bought them before from you like 3 years ago. I will find out this week once the front diff gets torn down what ill need. Thanks for the reply.
#569
GM 8.6 Carrier Install Bearing & Shim Kit - Ron's Machining Service
Thanks, Ron
